2012-01-11, 15:40
2012-01-11, 16:11
Not that I know of, but you could use export library to seperate files option.
2012-01-11, 16:13
Mudislander Wrote:Not that I know of, but you could use export library to seperate files option.
I think you can automate that using scripts
2012-01-11, 16:17
Martijn Wrote:I think you can automate that using scripts
Looking forward to your next script !!
2012-01-11, 18:24
Would be nice to have one
I have multiple XBMC instances in my home, if NFOs would be generated automatically i´d only have to scrape the infos once. No, I don´t want to use mysql
2012-01-11, 18:45
LAW-Mastermind Wrote:Would be nice to have one
I seem to remember there being an advancedsettings option to auto export when updating but I didn't see it in the Wiki..may have been a few years and versions ago. Although a script will work I think using the XBMC functions the entire library will get exported every time you run it not just the new items.
You could also use something like Media Center Master set in XBMC mode which will look for new media and create the nfo's and metadata. I've played with it a bit on a WMC box and it works good.
Sickbeard also has an option to add metadata but it's more for media that's been added through it's own interface. It does have an option to process and existing folder but it's nothing that can be automated.
