Hello, does anyone know how to arrange the favorite list to make newly added items to show up on top?
Thanks in advance!
Context Menu > Move up or Down
Hitcher Wrote:Context Menu > Move up or Down
Hi and thanks for the tips!
But imagine you have 10 items on that list. Then you need 10 times "Context Menu > Move up" for each newly added item to make it move to the top. Next time you need 11 moves and so on...
That's why I'd like to reverse the default sort order if possible.
Btw, anyone knows if the favorite list sort order is hard-coded or alterable by the skin?
Just edit your favourites.xml found in your userdata folder.
Hitcher Wrote:Just edit your favourites.xml found in your userdata folder.
That might work out just fine for me but I suspect my wife and children won't be very happy with that solution ;-)
