2012-01-13, 21:27
Hello there, I've just discovered XBMC and it seems like this wonderful program could solve every problem I've ever had with digital media but I'm having a few problems that I hope you guys would be willing to help with. I've tried my best with the search button but I haven't found anything that's solved my problems yet.
1) Some of the TV shows I've added to XBMC don't seem to be showing up in my library.
House for example does not even though it is stored in "D:\Videos\TV\HOUSE\Season01" with each episode labelled "House - S01E01 - episode name" ect. It appears in TV Shows/Files but not in the main TV Shows directory.
2) Battlestar galactica's entire first series is showing up as the first episode even though all episodes appear to be named correctly. Again this only happens in the TV Shows main directory and works correctly in TV Shows/Files
3) Among others Futurama is missing most of it series's even though they are all present and correct in the TV Shows/Files folder again.
Now I've written all of this out it seems like most of my problems stem from the TV Shows folder not working correctly. I'm using the Night theme currently but it doesn't seem like they show in any theme I tested.
4) Not a biggie but the weather page doesn't seem to load at all even after I've fed it the correct area codes.
5) Is it possible to group my movies together? For example can I put the 4 Alien movies in release order and not have Aliens be last.
According to the details page on My Computer I'm using version 10 of XBMC on Windows 7 64-bit.
Thank for any help you give. I really want this to work lol.
