(2012-03-19, 22:57)europorsche914 Wrote: [ -> ] (2012-03-19, 22:31)jfoley Wrote: [ -> ]I have a "Logos" folder, "affiliates.xml", "channelmap.csv", "logomapper.exe", "logos.xml", "mc2xml.dat", "mc2xml.exe", "xmltv.xml".
I have also tried IE and it isn't working either. Pretty much the same result in IE. I VLC 2.0.1 installed with a "Complete" install. I assume this includes the IE plugin. None the less, I think I have two issues. First, the channel information isn't displaying and the second is the video play back in the web.
Should we take this to a private conversation?
uspino Wrote:It's working for me in Chrome, no problems whatsoever...
@uspino good I'm glad to here that and bad cause I gotta solve that issue with the other computer lol
@jfoley if it's ok with you we can solve it here so all can benefit plus I'll be busy for a couple hours and someone else may chime in in the mean time. Ok so can you tell us:
1. Version of IE
2. Has remoteCeton been granted the ports it requires by windows firewall?
3. Do you have any other firewall/antivirus software
4. Please use the code tag and copy/paste what is displayed in the remoteCeton command window when the program first runs and after opening the webgui in IE
5. And just to confirm you have not created a custom channelmap.csv file correct.
That's a good start
Ok, here it goes.
1) IE 9.0
2) Windows Firewall has been turned off for a few days, still have the problem
3) No other firewalls/AV at this point. Fresh build of PC
4) ===================================================
Initializing : remoteCeton v1.9.9 | mcheng827@gmail
Found Device: Ceton InfiniTV PCIe (00-80-5b-3c)
Ceton: Loaded channel map from file
Tuner[1]: Loading tuner from device
Tuner[1]: Ceton InfiniTV PCIe (00-80-5b-3c) Tuner 1
Tuner[3]: Loading tuner from device
Tuner[3]: Ceton InfiniTV PCIe (00-80-5b-3c) Tuner 3
Tuner[4]: Loading tuner from device
Tuner[4]: Ceton InfiniTV PCIe (00-80-5b-3c) Tuner 4
Server: Starting up scheduler thread
Server: Starting up listener thread
Server: Press enter to shutdown...
5)===================================================
Server: Client requested file 'index.html'
Server: Client requested channel map data
I have not created a custom channel list, yet.
