2012-03-21, 03:05
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
2012-03-21, 03:32
(2012-03-21, 03:05)mcheng89 Wrote: [ -> ]which one do you like better?
D@mn that 2nd one looks just like media center! Second one is fine with me.
EDIT: I have messed with that iphone.html but cant seem to figure out some things, I fear it maybe over my head.. I cant figure out how to remove "CetonTV.views.channelTabs" without breaking it.. Trying to switch to indexBar for jumping to a range of channels
2012-03-21, 15:08
VLC 2.0.1 is causing issues (thanks @jfoley)... VLC 2.0.0 download link is here: http://download.videolan.org/pub/videola...-win32.exe
2012-03-21, 15:24
Yep, downgrading to VLC 2.0.0 fixed this issue. Can you also help me figure out my Xoom 4.0 ICS Android Tablet? I am using Chrome Beta browser. If I use the normal layout it says "No plug-in available to display this content" where on a desktop the VLC plug-in would normally be. If I click on Iphone compatible view when I double click on a channel is just says "Loading". I can see on the host, it tunes the tuner (changes res, set the channel) but nothing happens on the tablet. Just says "Loading" and that will go away after a few seconds.
**EDIT**
Ok, I switched to the stock browser and it opened "Video Player" but then said "Sorry, this video cannot be played back"?
**EDIT**
2012-03-22, 03:16
(2012-03-21, 15:24)jfoley Wrote: [ -> ]Yep, downgrading to VLC 2.0.0 fixed this issue. Can you also help me figure out my Xoom 4.0 ICS Android Tablet? I am using Chrome Beta browser. If I use the normal layout it says "No plug-in available to display this content" where on a desktop the VLC plug-in would normally be. If I click on Iphone compatible view when I double click on a channel is just says "Loading". I can see on the host, it tunes the tuner (changes res, set the channel) but nothing happens on the tablet. Just says "Loading" and that will go away after a few seconds.
**EDIT**
yea it looks like mine is broken too...
edit: adding flash support (we can use that as an alternative for now)
2012-03-22, 15:43
(2012-03-22, 03:16)mcheng89 Wrote: [ -> ](2012-03-21, 15:24)jfoley Wrote: [ -> ]Yep, downgrading to VLC 2.0.0 fixed this issue. Can you also help me figure out my Xoom 4.0 ICS Android Tablet? I am using Chrome Beta browser. If I use the normal layout it says "No plug-in available to display this content" where on a desktop the VLC plug-in would normally be. If I click on Iphone compatible view when I double click on a channel is just says "Loading". I can see on the host, it tunes the tuner (changes res, set the channel) but nothing happens on the tablet. Just says "Loading" and that will go away after a few seconds.
**EDIT**
Cool, let me know if you need a tester.
2012-03-23, 01:19
2012-03-23, 05:39
test this please!
Completely rewritten web interface using flash (no need for vlc! but you dont get direct streaming)
europorsche914's VLC web interface was renamed to vlc.html (if you want direct streaming you need to use this)
http://www.mediafire.com/?rddyy71ynx6ls0x
the settings window isnt that nice... didnt want to spend too much time
Quick instructions (basically exactly like the xbmc interface):
- Arrow keys move around epg
- Entering numbers jumps to a channel
- Esc switches to full screen
2012-03-23, 16:57
Post removed
2012-03-23, 21:23
Hey guys, awesome work your doing here. I am about to move into a new house and think I need to integrate live TV in with my current XBMC setup. Have any of you tried streaming to multiple XBMC's at the same time? does anyone have a video of what the channel switching process looks like?
I will have XBMC running in 4 rooms and if I could get all them streaming a different live TV channel that would be amazing.
currently have 3 xbmc buntu and 1 xbmc IOS.
Thanks,
Krys
Thanks,
Krys
2012-03-24, 04:07
Looks good. I still can't get it to work with my Xoom using Chrome beta browser. The box shows "jwplayer" with a play icon over the video portion but when I click the video it opens up //localhost:8559. The Iphone page just says "Loading" and never goes anywhere.
Also, from the desktop, it doesn't appear to work with Chrome unless I am missing some type of plug-in? Worked in IE although once I got full screen I couldn't get it back out of full screen? I pressed ESC, nothing happened.
2012-03-24, 20:11
I am also curious if there is any future possibility of Picture in picture, or a multiview with all 4 tuners?
2012-03-25, 03:29
@jfoley: I didnt fix android yet. the flash code is there but I havent put it in for android yet.
@allen00se: not sure if I'm going to put those features in... maybe someone else can develop an interface to do that.
Also, I have a fix for vlc 2.0.1. I'll fix it tomorrow along with the android fix
2012-03-25, 04:32
I just found this and thank you for your work on it. I'm having some issues though. I have an HDHomeRun Dual hooked to a OTA antenna. When I pull EPG data it does not seem to map correctly.I have tried pulling from MS and schedules direct. I think the issue is with over the air channels having multiple broadcasts (5.1, 5.2, 17.1, 17.2 and so on). So I guess the problems are:
1. EPG only shows 'main' channels. 4,5,11... and not 4.1, 4.2, 4.3
2. EPG is not showing any data. everything says 'no program data'
3. some channels are not correct. channel 4 (pbs) shows up in the epg but when you choose it nothing happens. channel 7 (nbc) shows up but when you choose it, it plays channel 17 (nbc).
Any suggestion where I start or what info I can provide you to help fix this? Also, what PVR build do you suggest? right now I'm running vanilla eden and I would like to use the PVR addon
Havoc
Edit - Here is the scan log
Here is the links that HDhomerun generates for channel 5:
hdhomerun://10324E73-0/tuner0?channel=8vsb:677000000&program=3 <--5.1 tuner 1
hdhomerun://10324E73-1/tuner1?channel=8vsb:677000000&program=3 <--5.1 tuner 2
hdhomerun://10324E73-0/tuner0?channel=8vsb:677000000&program=4 <--5.2 tuner 1
hdhomerun://10324E73-1/tuner1?channel=8vsb:677000000&program=4 <--5.2 tuner 2
Havoc
Quote:SCANNING: 803000000 (us-bcast:69)
LOCK: none (ss=17 snq=0 seq=0)
SCANNING: 689000000 (us-bcast:50)
LOCK: none (ss=32 snq=0 seq=0)
SCANNING: 683000000 (us-bcast:49)
LOCK: 8vsb (ss=85 snq=89 seq=100)
TSID: 0x073F
PROGRAM 3: 50.1 WRAZ-HD
PROGRAM 4: 50.2 MeTV
SCANNING: 677000000 (us-bcast:48)
LOCK: 8vsb (ss=81 snq=87 seq=100)
TSID: 0x073B
PROGRAM 3: 5.1 WRAL_HD
PROGRAM 4: 5.2 WRAL-2
SCANNING: 671000000 (us-bcast:47)
LOCK: none (ss=23 snq=0 seq=0)
SCANNING: 647000000 (us-bcast:43)
LOCK: none (ss=28 snq=0 seq=0)
SCANNING: 641000000 (us-bcast:42)
LOCK: 8vsb (ss=63 snq=75 seq=100)
TSID: 0x074F
PROGRAM 3: 30.1 WRAY-SD
PROGRAM 4: 30.2 WRAY-HD
PROGRAM 5: 30.3 WRAYSD2
PROGRAM 6: 30.4 WRAYSD3
SCANNING: 635000000 (us-bcast:41)
LOCK: none (ss=19 snq=0 seq=0)
SCANNING: 629000000 (us-bcast:40)
LOCK: 8vsb (ss=49 snq=57 seq=100)
TSID: 0x17A7
PROGRAM 1: 26.2 WUVC-DT
PROGRAM 2: 26.1 WTNC-LP
SCANNING: 623000000 (us-bcast:39)
LOCK: none (ss=21 snq=0 seq=0)
SCANNING: 617000000 (us-bcast:38)
LOCK: 8vsb (ss=71 snq=85 seq=100)
TSID: 0x0715
PROGRAM 1: 40.1 WUVC-DT
PROGRAM 2: 40.2 WTNC-LP
SCANNING: 611000000 (us-bcast:37)
LOCK: none (ss=22 snq=0 seq=0)
SCANNING: 557000000 (us-bcast:28)
LOCK: 8vsb (ss=79 snq=90 seq=100)
TSID: 0x0713
PROGRAM 3: 28.1 WRDC-HD
PROGRAM 4: 28.2 CoolTV
SCANNING: 551000000 (us-bcast:27)
LOCK: 8vsb (ss=89 snq=89 seq=100)
TSID: 0x073D
PROGRAM 3: 22.1 WLFL-HD
PROGRAM 4: 22.2 Country
SCANNING: 545000000 (us-bcast:26)
LOCK: none (ss=39 snq=0 seq=0)
SCANNING: 539000000 (us-bcast:25)
LOCK: 8vsb (ss=64 snq=76 seq=100)
TSID: 0x0701
PROGRAM 3: 4.1 UNC-TV
PROGRAM 4: 4.2 UNC-KD
PROGRAM 5: 4.3 UNC-EX
SCANNING: 533000000 (us-bcast:24)
SCANNING: 527000000 (us-bcast:23)
LOCK: 8vsb (ss=55 snq=67 seq=100)
TSID: 0x0725
PROGRAM 3: 25.1 UNC-TV
PROGRAM 4: 25.2 UNC-KD
PROGRAM 5: 25.3 UNC-EX
SCANNING: 521000000 (us-bcast:22)
LOCK: none (ss=26 snq=0 seq=0)
SCANNING: 491000000 (us-bcast:17)
LOCK: 8vsb (ss=79 snq=85 seq=100)
TSID: 0x0719
PROGRAM 3: 17.1 NBC17HD
PROGRAM 4: 17.2 NBC17SD
SCANNING: 485000000 (us-bcast:16)
LOCK: none (ss=25 snq=0 seq=0)
SCANNING: 479000000 (us-bcast:15)
LOCK: 8vsb (ss=58 snq=59 seq=100)
TSID: 0x0743
PROGRAM 3: 47.1 ION
PROGRAM 4: 47.2 qubo
PROGRAM 5: 47.3 IONLife
SCANNING: 473000000 (us-bcast:14)
LOCK: none (ss=29 snq=0 seq=0)
SCANNING: 201000000 (us-bcast:11)
LOCK: 8vsb (ss=90 snq=86 seq=100)
TSID: 0x0711
PROGRAM 1: 11.1 WTVD-D1
PROGRAM 2: 11.2 WTVD-D2
PROGRAM 3: 11.3 WTVD-D3
SCANNING: 195000000 (us-bcast:10)
LOCK: none (ss=61 snq=0 seq=0)
2012-03-25, 14:49
OK I fixed the sub channels by modifying the channelmap file, see below:
41,WUNCDT,3,539000000
42,WUNCDT2,4,539000000
43,WUNCDT3,5,539000000
51,WRALDT,3,677000000
52,WRALDT2,4,677000000
111,WTVDDT,1,201000000
112,WTVDDT2,2,201000000
113,WTVDDT3,3,201000000
171,WNCNDT,3,491000000
172,WNCNDT2,4,491000000
221,WLFLDT,3,551000000
222,WLFLDT,4,551000000
281,WRDCDT,3,557000000
282,WRDCDT,4,557000000
301,WRAYDT,3,641000000
302,WRAYDT2,4,641000000
303,WRAYDT3,5,641000000
304,WRAYDT4,6,641000000
401,WUVCDT,1,617000000
402,WUVCDT2,2,617000000
471,WRPXDT,3,479000000
472,WRPXDT,4,479000000
473,WRPXDT,5,479000000
501,WRAZDT,3,683000000
502,WRAZDT2,4,683000000
503,WRAZDT3,5,683000000
I tried putting the dots in but it did not like that. The only thing I can't get to work now is the EPG... It is still reporting 'no program info'. Does the second column in the channelmap file have to match one of the "display-name" in the xmltv.xml file?
