(2012-06-28, 00:22)mcheng89 Wrote: [ -> ]got my raspberry pi... dont know if i'll start playing with it until the weekend though
Good for you!
Hope you make as much progress as you have done so far.
I never knew there was another "Complete Media Solution" out there called Plex. Looks pretty nice.
Ok, so I havent made any changes, but VLC 2.0.2 is out...
Hmm. I wonder if i would experience better results by having the A/V receiver doing the audio decoding instead of the pi
(2012-07-03, 00:34)mcheng89 Wrote: [ -> ]Raspberry pi running without any issues!
Using openelec and some settings I got off here: http://mrpfister.com/journal/setting-up-...pberry-pi/
Going to leave it on for about an hour to make sure there isnt any sync issues
So how did it go? What settings did you use? I am currently installing Linux so I can install openelec and I will see if I get the same results.
(2012-07-02, 04:34)mcheng89 Wrote: [ -> ]uploading a new version for the new VLC version
2.2.0: http://www.mediafire.com/?3z3czylq97zczq9
@gman3042: will post another build later today... or tomorrow
thx.. i've been running the xbmc app for a little while..it will usually go like 5-10 minutes without buffering.. otherwise works pretty good.. all under direct stream
also, does your version.. when you change the channel.. go back to the home screen (and then changes the channel and returns back to the app).. small cosmetic thing.. but a little weird
edit: also, ahs anybody been able to get channel logos working in the ceton pvr? i put channel logos all into teh same directory but its not taking any of them.
(2012-07-05, 05:38)gman3042 Wrote: [ -> ]edit: also, ahs anybody been able to get channel logos working in the ceton pvr? i put channel logos all into teh same directory but its not taking any of them.
I'll look into that too... This is for the web interface? I dont remember if the xbmc addon had logo support (but I can add it)...
this is for the pvr version.
(2012-07-04, 19:38)Acostanavy Wrote: [ -> ] (2012-07-03, 00:34)mcheng89 Wrote: [ -> ]Raspberry pi running without any issues!
Runs great! I only tried up to 720 though since I dont feel like the amount of cpu required for 1080 is worth it (I have other stuff running on my comp).
I just followed the high cpu section on that site. Theres windows install instructions here:
http://www.squirrelhosting.co.uk/hosting...o.php?id=9
EDIT: I did make a change to the vlc params. Will upload that version tonight.
EDIT2: Uploaded v2.2.1 -
http://www.mediafire.com/?k7dayp52hhay4o1
(2012-07-05, 14:41)gman3042 Wrote: [ -> ]this is for the pvr version.
yea, the xbmc addon/xbmc pvr versions never had logo support. its something I could look into though.
is 2.2.1 supposed to improven hdhomerun direct stream code? haven't downloaded it yet.. wanted to see if this version you made any chances
I have a problem where VLC crashes and I have to manually open VLC and dismiss the crash report popup, you can add this to the vlc command line to disable that (apparently)
--no-crashdump
(2012-07-07, 19:30)gman3042 Wrote: [ -> ]is 2.2.1 supposed to improven hdhomerun direct stream code? haven't downloaded it yet.. wanted to see if this version you made any chances
no, not yet. finished making the changes to the server, but I havent modified the xbmc client yet.
(2012-07-09, 06:45)DanTheMan827 Wrote: [ -> ]I have a problem where VLC crashes and I have to manually open VLC and dismiss the crash report popup, you can add this to the vlc command line to disable that (apparently)
--no-crashdump
i'lll add this
Glad you got it work work for the Pi. I had openelect installed and everything works but I still have a lag issue, even at 720P. I wonder what this could be since it is plugged in directly to the router. I even set the ARM CPU speed to 800 MHz. Since I work, school, and a family it is hard for me to try this daily. I will try again when I have a chance and see if it works. At least I know you have it working without any out of sync issues so it is possible.
Thank you!
