2013-08-14, 03:24
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
2013-08-14, 18:25
What is the best solution for avoiding the "no available tuners" error? I know that it can be temporarily fixed by restarting the server but that is not going to work as a long term solution. It happens seemingly randomly and it is a huge pain because it crashes XBMC on the client side
2013-08-15, 10:58
(2013-08-13, 03:51)mcheng89 Wrote: [ -> ](2013-08-12, 19:29)tallnerd1985 Wrote: [ -> ]Other than that, I would say going back to FFMPEG in your server should help reduce dependencies on 3rd party software of another 3rd party software. VLC is nice but when running a headless server, it only complicates things and such unless VLC can run headless without the GUI and such.
vlc doesnt run headless right now when you start a stream?
(2013-08-04, 03:54)Tripplesixty Wrote: [ -> ]2) From time to time if I change to a channel that I do not subscribe to the app will crash and leave me at the add-on page in XBMC where the app seems to not be completely closed. Many times I have to press escape or "x" to close the add-on. Sometimes I'm left closing and restarting xbmc.
I'll look into this.
Updated todo:
- remove unused channel group code - in progress
- infinitv 6 support
- cleanup some transcoding code for commercials
- edit the channel lineup in the webui
- fix logos (My Channel Logos app)
- web interface tweaks - mute/stop
- mobile interface update
- windows service/tray icon?
- plex channel - desktop client
- wmc friendly
- linux support
- handle errors in xbmc plugin more gracefully
diffidently PLEX support and LINUX... especially if you can get it to work with the PLEX android client
2013-08-20, 01:13
Any ceton infinitv 6 users (also infinitv4 to make sure nothing broke)?
can you test this:
http://www.mediafire.com/?8j47wye4h9arz5c
* Add silent command option to start program silently
* VLC transcode patched dlls for commercials (audio and video fix)
* Initial Ceton InfiniTV6 support
Looks like vlc 2.0.8 works!
In progress:
- fix some web interface bugs
can you test this:
In progress:
2013-08-20, 23:38
I tried the new Ceton 6 TV Server and it responded with this message
[8.20.2013.17:35:40]: Server: Initializing Devices
[8.20.2013.17:35:45]: CetonInfiniTV: Invalid tuner count
[8.20.2013.17:35:45]: Failed to add device: new Device[CetonInfiniTV4][192.168.0
.106]
[8.20.2013.17:35:45]: No devices were found
[8.20.2013.17:35:45]: Server: Ready event fired. Starting status page.
Did not find Ceton InfinityTV 6 Network device
.106]
2013-08-21, 04:25
I just thought I would post this, they are using WMC as the backend and its working great. I also have TV Server too. Might be able to work together and make an awesome set of TV Addons.
http://forum.xbmc.org/showthread.php?tid=171216&page=13
2013-08-21, 06:49
(2013-08-21, 04:25)drewscm Wrote: [ -> ]I just thought I would post this, they are using WMC as the backend and its working great. I also have TV Server too. Might be able to work together and make an awesome set of TV Addons.
I saw that being developed a while back before it was release. Maybe its time to move to that server?
(2013-08-14, 00:41)maseline_98 Wrote: [ -> ]How do I install the client on android?
http://<server ip>:<port>/m/iphone.html
(2013-08-20, 23:38)kp4akb Wrote: [ -> ]I tried the new Ceton 6 TV Server and it responded with this message
.106]
New version:
http://www.mediafire.com/?6ns5538wbrrqmol
Can you also change to the CetonInfiniTV6 device type in the settings page?
2013-08-21, 13:30
Thank you for the quick response, I have downloaded (http://www.mediafire.com/?6ns5538wbrrqmol) tvserver v0.6.0b and I am getting the same results.
You asked me to select to CetonInfinityTV6 but the device does not appear in the "Drop Down"
My procedure to make sure I am not missing something:
Download---http://www.mediafire.com/?6ns5538wbrrqmol
Extract with windows explorer
Go to TVserver folder and start TV application
Wait for web page to open and add device
Enter IP address number from Network settings for InfinityTV6
The select device from drop down. Only four device listed
Ed Rios
Ed Rios
2013-08-21, 20:00
The new version worked for me with Ceton 6 tuner
Thanks!!!!!!!
Guy
Thanks!!!!!!!
Guy
2013-08-21, 20:30
Spoke too soon it sometime works and sometime fails with "Could not get channel listing "
Guy
Guy
2013-08-21, 20:52
I have checked and the two newest versions break Ceton 4 (0.6.0(b)). The newest version(s) still work with HD Homerun Prime though.
2013-08-22, 00:58
(2013-08-21, 06:49)mcheng89 Wrote: [ -> ][quote='drewscm' pid='1488847' dateline='1377051924']
[quote='maseline_98' pid='1483843' dateline='1376433706']
The server side works great and the install is streamlined, installs on its own and put the pvvr in the addons and it works. The only front end is the addon for XBMC, that was the reason I brought it up, these two projects would work great together.
2013-08-22, 02:39
(2013-08-21, 13:30)kp4akb Wrote: [ -> ]Thank you for the quick response, I have downloaded (http://www.mediafire.com/?6ns5538wbrrqmol) tvserver v0.6.0b and I am getting the same results.
Ed Rios
That sounds right. I'll have to take a look.
(2013-08-21, 20:52)jfoley Wrote: [ -> ]I have checked and the two newest versions break Ceton 4 (0.6.0(b)). The newest version(s) still work with HD Homerun Prime though.
Yea. I'll have to reinstall my ceton device into my computer over the weekend to test it.
(2013-08-21, 20:30)guys2 Wrote: [ -> ]Spoke too soon it sometime works and sometime fails with "Could not get channel listing "
Guy
Sent you a pm.
Any developers interested in helping?
I'm thinking about porting the server to another language if that means more help . (it's coded in c++ right now)
2013-08-22, 04:22
Good News I downloaded the file again and this time it worked, TV server found the InfinityTV6
Day Later:
Bad news--TVServer does not find the InfinityTV6 tuners even after several reboots
Day Later:
2013-08-22, 09:35
I've had an issue lately where sometimes the TV stream is just a green video stream. Sound is fine, but the video is just a solid green screen. It seems to happen when I've left a flash window (twitch.tv or youtube for example) running on the server machine so I'm not sure how its related to that since this is using VLC to stream, right? Closing the browser window thats running flash fixes the problem but is there a way to avoid the problem in the first place? Has anyone else seen a green video stream?
tvserver v0.5.12 and VLC 2.0.5
edit: I'm guessing its related to this flash issue. I'll be disabling hardware acceleration to see if it fixes the stream going green issue.
