How do I disable the movie theater and tv screen from the main menu? I'd like to only see fanart, like Transparency's announced design goal.
check out the available options in:
Settings > Skin Settings > Backgrounds.
select the 'multi image' option and point a to a folder containing the fanart images.
tip: you can use the artwork organizer script to copy all your fanart to one folder.
Thank you! I had to re-install my XBMC due to crashed SSD, so I lost some settings.
I'd also like to thank you for your dedication in bringing Transparency to us. I've been using it for probably two years now almost daily, and I really enjoy the visuals!
