Full Version: can XBMC playback 3D Movies?
Pages: 1 2 3 4 5 6 7 8 9 10 11
Hi guys, all this time i always watched 2D movies on my HTPC.
anyhow, my friend bought an LG 3D FULL HDTV bundled with a LG bluray player.
so i went at his house thinking i could show him 3D playback 'on a computer'
but things went downhill...
i have an AMD Triple-Core CPU + HD6450 GPU + 4GB ram
these definitely can handle 3D 1080P movies.
but after playing with nearly all options in XBMC,
and media player classic,
i couldnt find the way to playback 3D correctly.
the file was a 3D MKV rip taken from the internet.
i know i know, maybe a bad rip, but it isnt...
my friend's LG bluray player played the MKV without a hitch!
it actually look fantastic!
but when i tried the same MKV in XBMC (windows7),
result was not good.
the two images seemed wayy too separated.
I could still see 3D with the glasses but it seemed weird and got tired....
Without the glasses I could clearly see the two images overlapped
but separated by at least ~5cm.
also, ~3 cm or so on each side were black when using the glasses, making the 3D image smaller.
i even took his HDMI 1.4 cable that was hooked on his LG bluray player
thinking it was maybe my HDMI cable that was culprit.
im far from being a 3D guru Tongue
i also played with nearly all options in my ATI control panel...
but in vain Sad
now, i dont know whats left for me to try....
is XBMC capable of handling 3D?
or i have to use PowerDVD or TMT5??
thanks.
I not too sure you could check here for answers i didn't read all the thread but sounds like they had some problems
I watched blu-ray in 3d with my inlaw HDTV last year using HD6450 GPU and TMT5. It worked very similar to the standalone 3d blu-ray player. I never try 3d with XBMC, and I doubt that it can playback fluently with XBMC. I configured TMT5 as shown in this tutorial- TotalMedia Theatre 5.
If you like it, you can setup TMT5 as an external player with this "playercorefactory". It'll playback "title_3d.mkv) using TMT5, and other "title.mkv" still playback with XBMC. Smile
xbmc plays 3d half sbs just fine.
But do not zoom the picture that's when you get that effect what you are saying that the picture is not on top of the other picture. When I watch a normal movie and it has those black bars in it, i usually zoom it a bit to 110% just to less of thos black bars. But you can't do that with 3d movies, because the 2 pictures won't be on top of each other and will cause that effect you are mentioning.
thanks guys for all the answers...
i'll definitely try TMT5 at my friends house next time.
however, i believe TMT5 wont fix the issues im experiencing in my 1st post.
the fact that the two images seemed wayy too separated.
I could still see 3D with the glasses but it seemed weird and got tired of it....
also, ~3 cm or so on each side of the screen is black when using the glasses,
making the 3D image smaller and not full screen.
also, RavenNL, i did not zoom in anyway shape or form...
but i've read while google'ing my issue, that someone appears to have fixed this issue by simply:
#1- setting the underscan/overscan in AMD CONTROL CENTER to "%0" ...
#2- setting his TV to "Just Scan" or "Screen Fit" in the aspect ration/image options
however, i haven't try that yet, but im eager to see if that will do it!!
thanks again guys
Well go try it out eskro! lol
I've been wondering about this myself but haven't played around with it yet. I'll probably just wait until MPC-HC or XBMC supports it as I am philosophically opposed to paying money for TMT or PDVD and then more for an update, and oh wait, more for the next update. I'd much rather donate it to the XBMC crew. Not to mention, those players just feel very bloated to me. Maybe they aren't but it just doesn't feel light and streamlined like XBMC and MPC do.
Anyway, good luck man. Let us know how you make out.
yes, i'll try to update this thread once i get a chance to try the fix...
dont know when i'll go to my friends house again...
we rarely have time to see each other as everybody has its own thing to do...
ahhh.. life... lol
eskro Wrote:thanks guys for all the answers...
You and your friend will like the 3D with TMT5...give it a shot! Smile
Me, I hate 3D stuff. I didn't enjoy the movie with 3D. It made me dizzzzzy! :o
eskro Wrote:is XBMC capable of handling 3D?
Yes it works for me. I just select 3d sbs on my tv 3d settings.
3D SBS:
Hunter2-1 Wrote:Yes it works for me. I just select 3d sbs on my tv 3d settings.
This is your TV simulating 3D SBS from a 2D picture. This will work on everything.
XBMC, as far as I know, does not natively support hardcoded 3D SBS (Side-By-Side) playback yet.
If your PC is capable of playing 2650x720 or 3840x1080 you might get away with it.
You can get an external player to replace 'DSPlayer' integrated into XBMC called Steroscopic Player which should do the job, you are going to need a very high end PC I reckon to run it.
Better info is discussed here. I cannot say for sure as I have avoided the 3D hype.
oh boy, this is confusing Tongue
3D-SBS / FULL 3D / STEREOSCOPIC 3D /
o.O
eskro Wrote:oh boy, this is confusing Tongue
o.O
With proper GPU and TMT5 or PDVD11, there is no confusion. Give it a shot! Smile
maybe an overscan/underscan problem...
in the aspect ratio settings of the tv, use the setting "just scan"
on the pc disable the overscan/underscan setting by setting it to 0
see if that works for you
Hunter2... how did you label your movies so the thumb shows it as a 3d movie.. Mine have been not finding the images for the thumb with the 3d in the title
Also what Skin are you using... it looks really nice!
Thanks for the help
ohh and my 3D movies work fine in XBMC
@Crevan: will do as soon as i can, thx
@cleaner450: i think its --> Avatar (2009)[b]_3D[/b] / Avatar (2009)[b]_3D.MKV[/b]
