UP, I would be interested too to see if there is a solution to that.
try that solution
sample link
http://cdn8.video.az:1935/dvr/_definst_///mp4:pub/video/12013/6/64/578/664578722478.mp4/manifest.f4m
inside that file
PHP Code:
<manifest xmlns="http://ns.adobe.com/f4m/1.0">
<id>pub/video/12013/6/64/578/664578722478.mp4</id>
<width>640</width>
<height>384</height>
<duration>1186.04</duration>
now rebuild link
http://cdn8.video.az/pub/video/12013/6/64/578/664578722478.mp4
here is your playable link
also i need some help
i need to find f4m adress from first page
http://video.az/assets/player/player.swf?st=p8kVe19GxU2a2v0GxQFgxUIDxU0bevoRxU7dnN5dpNXVNUXVciL5xZIGs8kGwmOO&pl=p8kVe19GxU2a2v0GxQFgxUIDxU0bevoRxU7dnN5dpNXVxUX5eQ55xuJDX1JO
could you help me that ?[/i]
try
http://cdn8.video.az:1935/dvr/_definst_///mp4:pub/video/12013/6/64/578/664578722478.mp4/master.m3u8
instead. the f4m is usually just used as a silly flash wrapper on hls
(2013-04-06, 13:49)divingmule Wrote: [ -> ] (2013-04-06, 12:27)RedPenguin Wrote: [ -> ]I'm trying to do the same thing for this URL but not quite getting the URL:
http://cctvhds-f.akamaihd.net/z/cctvnews...RBINFQRHMM
What you have there is adobe HDS manifest. The only way I know to download is using K.S.V.'s hds script -> https://github.com/K-S-V/Scripts
I played with piping the script output to the xbmc player but never quite figured it out
Thanks again I kinda figured that stream was odd in same way to what I am used to with LiveStreams.
Anyway, I luckily found other links for the said stream but maybe if they go down I can try and figure something out by then.
