2012-01-15, 22:45
I'm using XBMC on an Apple Tv2, with iOS 4.4 installed. It was Jailbroken via SeasonsPassDoes anyone know know to stop the Get More List in Video Add Ons, from displaying a black list. I know what to do to get it back, but I'm having to do it every other day.
I don't know to provide a link to my XBMC log, so I just copied it; sorry.
15:31:19 T:104415232 NOTICE: -----------------------------------------------------------------------
15:31:19 T:104415232 NOTICE: Starting XBMC, Platform: Darwin iOS (11.0.0 AppleTV2,1, Version 5.0.1 (Build 9A406a)). Built on Dec 24 2011 (Git:20111222-22ad8e4)
15:31:19 T:104415232 NOTICE: special://xbmc/ is mapped to: /private/var/stash/Applications/XBMC.frappliance/XBMCData/XBMCHome
15:31:19 T:104415232 NOTICE: special://xbmcbin/ is mapped to: /private/var/stash/Applications/XBMC.frappliance/XBMCData/XBMCHome
15:31:19 T:104415232 NOTICE: special://masterprofile/ is mapped to: /var/mobile/Library/Preferences/XBMC/userdata
15:31:19 T:104415232 NOTICE: special://home/ is mapped to: /var/mobile/Library/Preferences/XBMC
15:31:19 T:104415232 NOTICE: special://temp/ is mapped to: /var/mobile/Library/Preferences/XBMC/temp
15:31:19 T:104415232 NOTICE: special://frameworks/ is mapped to: /var/stash/Applications/XBMC.frappliance/Frameworks
15:31:19 T:104415232 NOTICE: The executable running is: /var/stash/Applications/XBMC.frappliance/XBMC
15:31:19 T:104415232 NOTICE: Log File is located: /var/mobile/Library/Preferences/xbmc.log
15:31:19 T:104415232 NOTICE: load settings...
15:31:19 T:104415232 NOTICE: special://profile/ is mapped to: special://masterprofile/
15:31:19 T:104415232 NOTICE: loading special://masterprofile/guisettings.xml
15:31:19 T:104415232 NOTICE: Getting hardware information now...
15:31:19 T:104415232 INFO: Using analog output
15:31:19 T:104415232 INFO: AC3 pass through is disabled
15:31:19 T:104415232 INFO: DTS pass through is disabled
15:31:19 T:104415232 INFO: AAC pass through is disabled
15:31:19 T:104415232 INFO: MP1 pass through is disabled
15:31:19 T:104415232 INFO: MP2 pass through is disabled
15:31:19 T:104415232 INFO: MP3 pass through is disabled
15:31:19 T:104415232 DEBUG: Error: Requested setting (videoscreen.screenmode) was not found. It must be case-sensitive
15:31:19 T:104415232 NOTICE: Checking resolution 12
15:31:19 T:104415232 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
15:31:19 T:104415232 DEBUG: CPlayerCoreConfig::<ctor>: created player DVDPlayer for core 1
15:31:19 T:104415232 DEBUG: CPlayerCoreConfig::<ctor>: created player oldmplayercore for core 1
15:31:19 T:104415232 DEBUG: CPlayerCoreConfig::<ctor>: created player PAPlayer for core 3
15:31:19 T:104415232 DEBUG: CPlayerSelectionRule::Initialize: creating rule: system rules
15:31:19 T:104415232 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtv
15:31:19 T:104415232 DEBUG: CPlayerSelectionRule::Initialize: creating rule: hdhomerun/myth/rtmp/mms/udp
15:31:19 T:104415232 DEBUG: CPlayerSelectionRule::Initialize: creating rule: lastfm/shout
15:31:19 T:104415232 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtsp
15:31:19 T:104415232 DEBUG: CPlayerSelectionRule::Initialize: creating rule: streams
15:31:19 T:104415232 DEBUG: CPlayerSelectionRule::Initialize: creating rule: flv/aacp/sdp
15:31:19 T:104415232 DEBUG: CPlayerSelectionRule::Initialize: creating rule: mp2
15:31:19 T:104415232 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvd
15:31:19 T:104415232 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdfile
15:31:19 T:104415232 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdimage
15:31:19 T:104415232 DEBUG: CPlayerSelectionRule::Initialize: creating rule: sdp/asf
15:31:19 T:104415232 DEBUG: CPlayerSelectionRule::Initialize: creating rule: nsv
15:31:19 T:104415232 NOTICE: Loaded playercorefactory configuration
15:31:19 T:104415232 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
15:31:19 T:104415232 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
15:31:19 T:104415232 NOTICE: No settings file to load to load (special://xbmc/system/advancedsettings.xml)
15:31:19 T:104415232 NOTICE: No settings file to load to load (special://masterprofile/advancedsettings.xml)
15:31:19 T:104415232 NOTICE: Default DVD Player: dvdplayer
15:31:19 T:104415232 NOTICE: Default Video Player: dvdplayer
15:31:19 T:104415232 NOTICE: Default Audio Player: paplayer
15:31:19 T:104415232 NOTICE: Disabled debug logging due to GUI setting. Level 0.
15:31:19 T:104415232 NOTICE: Log level changed to 0
15:31:19 T:104415232 NOTICE: Loading media sources from special://masterprofile/sources.xml
15:31:20 T:104415232 NOTICE: GL_VENDOR = Imagination Technologies
15:31:20 T:104415232 NOTICE: GL_RENDERER = PowerVR SGX 535
15:31:20 T:104415232 NOTICE: GL_VERSION = OpenGL ES 2.0 IMGSGX535-63.14.2
15:31:20 T:104415232 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.0
15:31:20 T:104415232 NOTICE: GL_EXTENSIONS = GL_OES_depth_texture GL_OES_depth24 GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_texture_float GL_OES_texture_half_float GL_OES_vertex_array_object GL_EXT_blend_minmax GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_discard_framebuffer GL_EXT_read_format_bgra GL_EXT_separate_shader_objects GL_EXT_shader_texture_lod GL_EXT_texture_filter_anisotropic GL_APPLE_framebuffer_multisample GL_APPLE_rgb_422 GL_APPLE_texture_format_BGRA8888 GL_APPLE_texture_max_level GL_IMG_read_format GL_IMG_texture_compression_pvrtc
15:31:20 T:104415232 NOTICE: initializing playlistplayer
15:31:20 T:104415232 NOTICE: DONE initializing playlistplayer
15:31:22 T:104415232 NOTICE: initialize done
15:31:22 T:104415232 NOTICE: Running the application...
15:31:22 T:105209856 NOTICE: -->Python Interpreter Initialized<--
15:31:23 T:104415232 NOTICE: ES: Starting event server
15:31:23 T:124272640 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
15:31:23 T:124272640 NOTICE: UDP: Listening on port 9777
15:31:23 T:104415232 NOTICE: starting zeroconf publishing
15:31:23 T:123740160 NOTICE: -->Python Interpreter Initialized<--
15:31:23 T:105209856 ERROR: /var/mobile/Library/Preferences/XBMC/addons/plugin.video.pelisalacarta/core/scrapertools.py:21: DeprecationWarning: the md5 module is deprecated; use hashlib instead
import md5
15:31:23 T:105209856 NOTICE: PLATFORM_NAME=xbmceden
15:31:23 T:105209856 NOTICE: [config.py] xbmceden config 3.2
15:31:23 T:105209856 NOTICE: [config.py] runtime path = /var/mobile/Library/Preferences/XBMC/addons/plugin.video.pelisalacarta
15:31:23 T:105209856 NOTICE: [config.py] data path = /var/mobile/Library/Preferences/XBMC/userdata/addon_data/plugin.video.pelisalacarta/
15:31:23 T:105209856 NOTICE: [config.py] temp path = /var/mobile/Library/Preferences/XBMC/temp/test
15:32:01 T:152457216 WARNING: FillBuffer: curl failed with code 22
15:32:01 T:152457216 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
15:32:01 T:152457216 ERROR: GetDirectory - Unable to get http directory
15:32:01 T:152457216 ERROR: GetDirectory - Error getting http://blutendes-xbmc.googlecode.com/svn...tendes/../
import md5
