2012-01-16, 00:50
2012-01-16, 01:02
2012-01-16, 02:55
I do that, but when I try to add the favorite I get the NO sign. Like the no smoking sign.
2012-01-16, 05:39
jbdd21 Wrote:I do that, but when I try to add the favorite I get the NO sign. Like the no smoking sign.
Are you using Eden Beta 1? If not, you are probably missing the favourites script...
Dharma - Eden-pre
Unzip the archive into your add-on folder, or install the .zip through the XBMC add-on browser.
I urge you to use Eden and XeeBo from Hitcher's repo. You will have the best compatibility, and what your trying to do will be much easier.
2012-01-16, 10:31
You either haven't added anything to your favourites or you didn't install via ZIP and you might not have the Favourites script installed.
Get it here -
http://mirrors.xbmc.org/addons/eden-pre/...avourites/
Get it here -
