Full Version: Subtitle button on OSD?
when I use the OSD, I can not find the Subtitle button? is there anything I missed? Huh
Thanks for the best skin Big Grin
You just need to set it up in skin options under the "scripts" heading.
Cheers
Sharpe Wrote:You just need to set it up in skin options under the "scripts" heading.
Cheers
thanks for your help Laugh
