2012-01-17, 03:26
I'm running XBMC live on a Dell Optiplex 740. The problem I'm having is that when I select suspend from the XMBC main menu, the display turns off, the hard drive shuts off, and that's it. The power light stays steady green and the internal fans stay running. The only thing you can do after that is a hard power-off (hold PWR button down for 5 seconds) and then afterwards it hangs during boot requiring a second hard power-off. I have no idea where to look after this. Suspends seems to work fine in Windows. Is there a log file or something I should be inspection?
