Full Version: HD channels slow and pixelated
Hi
First of all, thanx for the great work with the XBMC PVR branch :-)
I'm using this build on http://www.scintilla.utwente.nl/~marcelg....html#eden and MediaPortal as TV backend.
When watching an HD channel (720) the video is slow and pixelated. There is no problem when watching the same HD channels in MediaPortal.
Is this a known issue?
If you want me to post a log, i'll do it when i get home from work.
My MediaCenter is an ASUS eeeBox EB1501u: http://www.asus.com/Eee/EeeBox_PC/EeeBox...ifications
Have you tried the various options for de-interlacing? I have found different settings fix this problem on different platforms. I can't remember the options off hand, and finding the settings can be a bit painful. Under Video from memory, rather than Settings, but just keep digging around and you should find them, then just try different modes until you find one that (hopefully) works for your system.
