Hey guys, how do I hide a control when the screensaver is active? I've tried <visible>!Window.IsActive(screensaver)</visible> and IsVisible but neither work
tungmeister Wrote:anyone?
You could try using numeric window ID value.
pecinko Wrote:You could try using numeric window ID value.
Tried that as well and it didn't work.
2900 in case you didn't know.
Sounds like a possible bug, report it on trac.
Ye that's what I was starting to think, I'll trac it.
Where is the control you're trying to hide? One presumes that it's not in the screensaver window itself, so one presumes the screensaver in question is dim or black?
If so, try window 10097.
Thanks, good find Hitcher!
tungmeister Wrote:Thanks, good find Hitcher!
Will only be available in beta3 or Eden final at minimal
Martijn Wrote:Will only be available in beta3 or Eden final at minimal
Ye I know but at least it's been implemented, I don't mind waiting abit.
