Full Version: TV Shows with no usefulness
Good day.
What is the interest in using the menu "TV Shows" if it doesn't appear the files of the episodes that are in folders?
I can only use these files through the menu "Videos" \ "add" and use this custom choice.
After this, the menu appears as "Tv Shows" that has no usefulness.
What I'm doing wrong? Rolleyes
Thank you.
When you scan your tv shows into your library, the tv shows are organized using the meta data fetched locally or from the net. So tv shows menu directs you to your tv shows library. Clicking on a tv show should show you episodes if they are scanned. Please read up the XBMC manual.
