Full Version: The PVR manager has been enabled without any enabled PVR add-on.
I am running Ubuntu 11.10, and the pulse-eight xbmc with pvr.
I had an older version of xbmc installed from pulse-eight, and yesterday i deceided to update it, right or wrong, i ran the script available here : https://github.com/Pulse-Eight/xbmc/tree/477e921
The install seemed to work fine, but now the pvr function does not work for me, i am using Mediaportal (on another machine) as backend.
I get this error message : "The PVR manager has been enabled without any enabled PVR add-on. Enable at least one add-on in order to use the PVR functionality."
I have tried disabling/enabling both the pvr manager & the mediaportal addon, restarting my whole os between each change, but no help.
Also found some suggestions that i delete ~/.xbmc/userdata/Database/Addon*.db
file, which i tried, but no change.
Any help on this would be very appreciated, i cannot get any logs at this moment, but if needed i can upload them.
BR
pastebin the log please.
Here is the log :
http://pastebin.com/7CP5z1WP
Many thanks for the help!
BR
PG
delete ~/.xbmc/userdata/Database/TV*.db
it contains invalid data and can't be upgraded for that reason, which results in the failed load
Many many thanks for your help dushmaniac!
Worked perfectly!
BR
Patric
I ran into this error because I was playing with all the XBMC settings, and turning on options.
Settings | TV Settings | General | I clicked enabled without installing any PVR Addin's. Took me a while to find the setting I turned on, and this was the first forum post I came across with the error message.
Hope this helps future me Wink
How do I do the same? Where do I find that script?
One thing that I never see anywhere is how to find the script,
i,ve the same proble of mrpg, with my nexbox a95x (android 6,01) and lodi 16.1 jarvis. tried follow opdenkamp suggestion... but problem persist
this is my log
http://pastebin.com/iJZWyBKP
thanks in advance for each help
