2012-01-20, 12:46
I have encountered a new problem.
I added my library (TVShows/Two shares in one) with about 40 TVShows(700GB).
After the share is added I got a question about fetching information about the library, I choose Yes. It then began do work it way through the library but it took ALOT of time, after 2 hours it was almost finished and then it sayd that it could not communicate with the remote server!? I got a new question if I wanted to go on or stop the fetcher.
XBMC have not worked that well so this is far from the first time that I add a share and I canĀ“t remeber that it took over 2 hours!?
My library is built with Ember(Media Manager) so all information(nfo, fanart, thimbs, etc) that is needed is in the folders. XBMC should not need to fetch anything from internet so I dont get why its so slow?
Then about the faild communication. My computer with the library is running Windows7 and it does not just stop communicating. Its however not the first time that openelec complains about not able to connect to the server but it only accoures while fetching data when I have added a new share.
Maby its not my computer that is not responding but a online/internet server that is not responding? How could I know? There is really no need for it to go on internet to fetch information, everything is in the correct folder with the correct namings.
Hardware : Zotac ND22
