In the Home screen options from Home Window options where you enable the custom startup focus of the main menu in the Enter number of positions. When I tried to correct the number in the field, a numeric keypad pops up with C and OK buttons as well. The C button does not clear the entry so I can't edit the field at all.
Great skin. My all-time favorite.
I encountered similar problem, but when attempting to clear the number I've actually got several digits entered. Now it seems XBMC will not start. Its stuck on the initial logo screen. Since this was the only setting changed recently I wondering if anyone knows how to clear this without launching XBMC.
edit your guisettings.xml and look for
edit the value there and restart xbmc.
lol, I had some ridiculous number in the billions in there so when I left it on the logo screen all last night, this morning xmbc had finally started after it cycled through the number.
Anyway, I reset the setting per your post and worked perfectly. Many thanks.
