Full Version: I can't run my scripts at startup
i have had a quick look around searching and checking the online manual. if it covers this then i missed it, sorry...
basically i have installed the callerid scripts into my script folder e:\apps\xbmc\scripts
i have edited the autoexec.py scripts which now says this:
#xbmc.executescript('q:\\scripts\\callerid.py')
#xbmc.executescript('q:\\scripts\\playlistrandom\\playlistrandom.py')
but, the callerid script does not run when i startup the xbox.
what i think may be related is that i do not appear to have a q:\ drive letter when looking via ftp. i seem to recall i once did. i have been building my own versions of xbmc using xbmc_ddr. could i be missing some configuration item that should be making this q:\ drive mapping appear, or am i just doing something else wrong with the python script.
btw. it runs fine when i manually select the script.
i also run xbmc as my dashboard. my home path is set to e:\apps\xbmc\ so this is correct also.
any help would be appreciated, thanks.
the # refers to a comment - remove it.
you always have a q: drive - it's the virtual drive that xbmc's homedir is mapped to.
that was it! thank you. i feel a bit of a stupid now. :thumbsup:
