After I installed the Eden beta, I installed a fresh new Back Row, but something is missing.
The old version was designed so that there was a theater curtain that bran to side, followed by applause
when you started XBMC up, but it is removed in the Eden version.
So I want to know how, if possible, to activate it agin.
Just added it back to the svn
Sharpe Wrote:Just added it back to the svn
Sorry...svn, what ?? ok, Subversion, right !?
Yes you can either get the changed startup file from there (the SVN) and place it in the skins 720P folder:
Link
Or install the skin from the Passion repository and wait for it to update (usually in the evening).
Or just download the skin from the downloads link in my signiture.
It'll be updated in the main XBMC repository probably in a few weeks.
Sharpe Wrote:Yes you can either get the changed startup file from there (the SVN) and place it in the skins 720P folder:
Link
OK I got it, thanks for the help
