Full Version: [Live] 5.1 Sound work but not simple 2.0/2.1?
Version : xbmc-10.1-live
USBInstaller : LiLi
Architecture : 64 bits
Hardware : Zotac HD-ND22
Skin : Aeon NOX
Problem : When playing mkv 5.1 movies the sound works fine but when playing smaller avi files with 2.1 or 2.0 sound there is not coming any sound at all?
The audio settings Im using is these
Audio output : Optic/Coax
Speaker Config : 5.1
Boost Volume level on downmix : true
Dolby Digital (AC3) capable reveiver : true
DTS capable reveiver : true
Audio output device : default
Passthrough outpit device : ?
Examples :
This is not working :
Quote:General
Complete name : X
Format : AVI
Format/Info : Audio Video Interleave
File size : 350 MiB
Duration : 43mn 20s
Overall bit rate mode : Variable
Overall bit rate : 1 129 Kbps
Writing application : Some super fast AVI muxer
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 43mn 20s
Bit rate : 963 Kbps
Width : 624 pixels
Height : 352 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.183
Stream size : 299 MiB (85%)
Writing library : XviD 70
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Codec ID : 55
Codec ID/Hint : MP3
Duration : 43mn 20s
Bit rate mode : Variable
Bit rate : 153 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 47.5 MiB (14%)
Alignment : Aligned on interleaves
Interleave, duration : 24 ms (0.58 video frame)
Interleave, preload duration : 40 ms
This is working :
Quote:General
Complete name : X
Format : Matroska
Format version : Version 2
File size : 7.95 GiB
Duration : 1h 30mn
Overall bit rate : 12.5 Mbps
Encoded date : UTC 2011-10-20 18:37:44
Writing application : mkvmerge v4.9.1 ('Ich will') built on Jul 11 2011 23:53:15
Writing library : libebml v1.2.1 + libmatroska v1.1.1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 30mn
Bit rate : 11.9 Mbps
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.323
Stream size : 7.39 GiB (93%)
Writing library : x264 core 118 r2085 8a62835
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=19 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=11910 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 1h 30mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Bit depth : 16 bits
Stream size : 415 MiB (5%)
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:08:37.016 : en:00:08:37.016
00:17:40.518 : en:00:17:40.518
00:25:57.806 : en:00:25:57.806
00:36:02.827 : en:00:36:02.827
00:41:23.398 : en:00:41:23.398
00:45:04.118 : en:00:45:04.118
00:54:16.086 : en:00:54:16.086
01:00:17.155 : en:01:00:17.155
01:07:16.324 : en:01:07:16.324
01:14:25.336 : en:01:14:25.336
01:24:56.049 : en:01:24:56.049
What's the output of aplay -l? You might need a custom asound.conf or .asoundrc file. The codecs between the two files are different. One is mp3 and the other is AC3. Check you xmbc log file and see if anything audio wise is failing as well.
pumkinut Wrote:What's the output of aplay -l? You might need a custom asound.conf or .asoundrc file. The codecs between the two files are different. One is mp3 and the other is AC3. Check you XBMC log file and see if anything audio wise is failing as well.
Im new to XBMC Live and I do only use Window at regular bases so I need som help here.
What is aplay -l? How do I execute it?
I know how to activate the debug but how do I get it? I supose that the log will not be shared over SMB as default?
I have runned openElec before and the sound worked just fine there (with the same settings in XBMC).
