Full Version: how do you make bulk folders
I'm about to make the jump to eden beta 2, but i need to export my library. my problem is I have 100 films not in folders, just on their own and want to put them in their own folder, so i can export fanart etc into them.
the question is , how do you do it? does anybody know of a easy programme i can use?
thx
Not used it in a while but I believe Ember Media Manager had this feature.
http://forum.xbmc.org/showthread.php?tid=116941
I picked this up a while back in these forums... so don't thank me.
@echo off
for %%a in (*.*) do (
md "%%~na" 2>nul
move "%%a" "%%~na"
pause
Using notepad
Copy & Paste the above between the dotted lines only... call it batch_folder.bat. Stick it in a folder with 'only' those files you want
a folder made... Click the .bat and they all get folders and the files get inserted including the .bat
careful here....
everything gets a folder with the same name as the file.
