appears srt subs are totally broken atm
10-05-2005 23:48:20 debug msg:mplayer_open_file(g:\movies\shark.tale.ws.dvdrip.xvid-alliance\alli.st.xvid.avi)
10-05-2005 23:48:20 info stating file g:\movies\shark.tale.ws.dvdrip.xvid-alliance\alli.st.xvid.avi.conf
10-05-2005 23:48:20 info stating file q:\system\players\mplayer\g:\movies\shark.tale.ws.dvdrip.xvid-alliance\alli.st.xvid.avi.conf
10-05-2005 23:48:20 debug msg:playing g:\movies\shark.tale.ws.dvdrip.xvid-alliance\alli.st.xvid.avi.
10-05-2005 23:48:20 debug msg:auto open z:\subtitle
cache fill: 0.00% (0 bytes)
10-05-2005 23:48:20 debug msg:avi file format detected.
10-05-2005 23:48:21 debug msg:video: [xvid] 576x304 12bpp 23.976 fps 949.5 kbps (115.9 kbyte/s)
10-05-2005 23:48:21 debug msg:clip info:
10-05-2005 23:48:21 debug msg: software: nandub v1.0rc2
tarting lookup for subs
ub: detected subtitle file format: subviewer
ub: read 880 subtitles
10-05-2005 23:48:21 debug msg:.
ub: adjusted 13 subtitle(s).
10-05-2005 23:48:21 debug msg:global subsize: 1 - vobsub: -1, demux: -1, subs: 0
10-05-2005 23:48:21 debug msg:global subpos : 0
10-05-2005 23:48:21 debug msg:==========================================================================
10-05-2005 23:48:21 debug msg:opening audio decoder: [mp3lib] mpeg layer-2, layer-3
10-05-2005 23:48:21 debug msg:audio: 48000 hz, 2 ch, 16 bit (0x10), ratio: 4000->192000 (32.0 kbit)
elected audio codec: [mp3] afm:mp3lib (mp3lib mpeg layer-2, layer-3)
10-05-2005 23:48:21 debug msg:opening video decoder: [ffmpeg] ffmpeg's libavcodec codec family
elected video codec: [ffodivx] vfm:ffmpeg (ffmpeg mpeg-4)
10-05-2005 23:48:21 debug msg:checking audio filter chain for 48000hz/2ch/16bit -> 48000hz/6ch/16bit...
10-05-2005 23:48:21 debug msg:af_pre: af format: 2 bps, 2 ch, 48000 hz, little endian signed int
10-05-2005 23:48:21 debug msg:af_pre: 48000hz 2ch signed 16-bit (little-endian)
10-05-2005 23:48:21 debug msg:ao: [win32] 48000hz 2ch signed 16-bit (little-endian) (2 bps)
10-05-2005 23:48:21 debug msg:building audio filter chain for 48000hz/2ch/16bit -> 48000hz/2ch/16bit...
tarting playback...
10-05-2005 23:48:21 debug msg:mplayer_open_file(g:\movies\shark.tale.ws.dvdrip.xvid-alliance\alli.st.xvid.avi) done 1.0000
10-05-2005 23:48:21 debug playback has started
10-05-2005 23:48:21 info activating window id: 12005
10-05-2005 23:48:21 notice start led control
10-05-2005 23:48:21 notice led control: playing video led is switched off!
10-05-2005 23:48:21 notice dim lcd on playback
10-05-2005 23:48:21 debug msg:vdec: vo config request - 576 x 304 (preferred csp: planar yv12)
10-05-2005 23:48:21 debug msg:vdec: using planar yv12 as output csp (no 0)
10-05-2005 23:48:21 debug msg:movie-aspect is 1.89:1 - prescaling to correct movie aspect.
10-05-2005 23:48:21 debug msg:vo: [directx] 576x304 => 576x304 planar yv12
10-05-2005 23:48:21 info created yuv texture
cant get them to appear when i select a ttf font, but they also dont work if i set a raw font
i know the movies i tested used to work ok
