Full Version: XBMC with Harmony Advance remote
Hi
Any one tell me how do i configure the harmony one with HP IR receiver.OVU400102/71
is there any trick to modify the config so harmony can play xbmc instead of window media player.
Harmony Advance?
Should also have a number.
Use Harmony Software and add device: Microsoft MCE Keyboard.
Then just use the software to map the buttons.
TeKo Wrote:Harmony Advance?
sorry its harmony one ?
See http://wiki.xbmc.org/index.php?title=Usi...in_Windows (the HP receiver is Microsoft compatible).
It's usual to use the MCERemote add-on or EliteGamer360's scripts to configure the IR receiver. Then you can make the green button do what you want rather than starting WMC.
JR
