Full Version: TheMovieDb scraper marked as broken?
I ended up here because I keep getting a pop up titled "The MovieDB", with a message that says: "Add-on has been marked as broken in repository. Would you like to disable it on your system?" Below this message is a "Yes" and "No" button. If I click yes, it continues to pop up every ten minutes or so. Is this something on my end, or is it in the add-on itself? I'm using an ATV2 on Eden
A debug log would be the first step. Enable debug logging (settings->system->debugging), post it on pastebin or similar.
See my sig for more details.
There was an update of that scraper to-night, sounds like you didn't get it... if you did and it didn't install properly... there is a roll-back feature in the new Eden and Beta 2 is great.
