does anyone have a script that simply allows me to right click a movie and have mpc classic play it? all the guides I can find have it where it automatically chooses mpc.. I would prefer the other way around and don't know how to do it.
If the guides you've found involve creating a
playercorefactory.xml, then basically follow them, but don't bother to make any <rules>.
Any external player you define will be available from the context menu under the "Play Using..." option.
Something like:
<playercorefactory>
<player name="MPC-HC" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Program Files\Media Player Classic - Home Cinema\mpc-hc64.exe</filename>
<args>"{1}" /fullscreen /close</args>
<hidexbmc>false</hidexbmc>
<hideconsole>false</hideconsole>
<hidecursor>false</hidecursor>
</player>
</players>
<rules action="prepend">
</rules>
</playercorefactory>
Because there are no rules MPC-HC won't be used automatically, but it will appear as an option under "Play using...".
JR
