Full Version: HD atv2 playback
Just double checking before I buy or dont buy an atv2. After getting xbmc installed on the atv2, can it play bluray iso's off of the server? Doesn't look like it does but just making sure.
FROM THE WIKI
"Formats and resolutions iOS devices can playback
XBMC on iOS can playback all formats supported by XBMC in standard definition. Due to technical limitations only H.264 (up to High Profile) encoded videos are supported for high definition. The iPad 2 and iPhone 4S are the only exceptions to this and will play some other HD codecs due to the more powerful CPU inside."
Bluray ISOs use H.264 High Profile (at least those following the Bluray spec. Not including 3D), so you should be fine. Several people have played Bluray ISOs on the ATV2 + XBMC without issue. Just be sure to use a wired ethernet connection.
forgot to respond back...Thanks for the reply...
