Full Version: Importing scraped data from a PC
I tried copying a large (250mb) userdata directory from my PC to my ATV2 running Eden B1. it showed no content. I restarted having set the directories (as per a new setup) and it rescraped everything making the datyabase enormous. My questions are given that I followed the Wiki, what did I do wrong (was it a Beta issue possibly?). Do I need to set up the directory. What If the content is identical but in a different NAS, should I just rescrape again? Whats the limit of the ATV2 i.e should you avoid large databases (400 movies plus)?
When you copied the userdata directory to the ATV2, did you set the permissions using the SSH command mentioned on the wiki?
No, I reset the permissions after rebooting a second time, so the answer is no I didnt immediately but retrospectively.
Also the fact that this "new" install l data structure is nearly
identical but for the NAS location, will it still work or is there something I need to set.
Thanks for your help.
