Full Version: XBMC Not Starting
I can't get XBMC to start. When I click the shortcut in the taskbar, it gives me the error:
Quote:CApplication::Create() failed - check log file and that it is writable
I first got the error on Eden Beta 1, and then updated to Beta 2, and the error persisted.
Computer Specs:
Windows 7 Professional SP1 64-bit
i7 2.67 GHz CPU
8 GB RAM
Integrated Graphics with most recent manufacturer drivers, since this is a tablet.
I have no clue about my sound card, and I heavily doubt it's the problem.
Log: http://pastebin.com/mVtZyqpM
Also, the log doesn't have the timestamps for anything since I've had the problem. It ends with the last time I closed the program.
EDIT:
Ok, I think I figured out the problem. Since I was using MakeMKV to stream the Blu-Ray I was watching to XBMC, then started using that program to rip the Blu-ray, it caused the log to be unwritable. I ended up deleting the log file, then the next time I used XBMC, it created a new one and works fine.
