dude, i did everything right but it still doesnt work, i have a mac and all 3 dont work? what should i do? give me check change log details
i cannot make this work can anyone help
is anyone working to fix this??
not working with me
what should i do
Hi all i am really need help . I wanna to know how i can get the " rtmp , swfUrl , pageUrl " for this link of channels :
http://www.teledunet.com/ .
Thank you .
hello everyone,
i installed livestream and aljazeera sports but im getting green screen with a cutting sound on my appletv 2, anybody has solution to this problem?
I'm also having problems with the Al Jazeera Sports section of this plugin
I have xbmc installed on my windows 7 32 bit pc and also on my Galaxy S3
On both platfoms I get the same poblem with Al Jazeera Sports, Audio plays fine but the video is blocked/choppy
Other sources in the same plugin i.e. Abu Dabai sports play fine
If there is already a post re this please point me in that direction or failing that does anyone have any ideas why these particular elements of the plugin may be failing
thanks in advance
I have windows Vista; I installed this plugin but it is not working!
Can some one help?
Tahnks
I have a subscription and a vpn for al jazeera. Is there an addon available where you can add your user id/pw in addon settings similar to that of tvcatchup?
Thanks for you effort, but I am getting error (playback failed. one or more items failed to play) I am trying them on IPAD and tried the 500.1000.240. same code
please help
(2013-08-21, 05:56)slivie Wrote: [ -> ]I have a subscription and a vpn for al jazeera. Is there an addon available where you can add your user id/pw in addon settings similar to that of tvcatchup?
In a similar situation!
(2013-08-27, 15:50)tspen Wrote: [ -> ] (2013-08-21, 05:56)slivie Wrote: [ -> ]I have a subscription and a vpn for al jazeera. Is there an addon available where you can add your user id/pw in addon settings similar to that of tvcatchup?
Likewise. Would be great to get an addon for Al Jazeera Sports subscription channels.
Salam, basically every time i try to play any channel it reply's with ''playback failed check the log files for details'' help me please?
