Anyone using remote Instruments over Wi-Fi to iPhone/iPad?
Problem is that my iDevice wont show up in the target area. Any ideas?
doesn't work over wifi ... you have to use the usb cable - but ipad only has 256mb of ram - doing memory leak check with instruments on it crashes xbmc because of lowmem... so better go with an iphone here if you can...
Memphiz Wrote:doesn't work over wifi ... you have to use the usb cable - but ipad only has 256mb of ram - doing memory leak check with instruments on it crashes xbmc because of lowmem... so better go with an iphone here if you can...
Ok, thanks for the update! I'll stick to the usb cable...
