Full Version: Quartz support for ESPN3 plugin
Hi guys,
First of all, I love this skin, it works so well on my Apple TV and just looks gorgeous. Bur I have a big, big problem with it, almost a deal breaker for me.
I watch a lot of sports through ESPN3 plugin and one of the coolest features is the Upcoming section where it tells you when the matches are coming up. In Confluence, it works perfectly, but in Quartz, the most important bit of info is missing, which is the scheduled date and time. I attached a screenshot from Confluence just to see what is missing, and I tried every view and none of them worked. Is there anything that I can enable to see it, or how hard would be to implement this. I so want to keep using this skin.
Thanks for reporting. Different plugins use different approach and it's impossible to cover all.
Did you have something like this in mind?
Yes, that is exactly what I was looking for. I can't get that view. Is this something you just coded in?
jabbba Wrote:Yes, that is exactly what I was looking for. I can't get that view. Is this something you just coded in?
This is Quartz Origins. I'll post an update for Quartz 2 shortly.
Thanks a lot.... moc děkuji
