hi,
I am really new with XBMC. I am using Mediaportal for years but I wanted to try something new ;-)
Here is my software setup:
- Windows 7
- Team Mediaportal 1.2.2Final including TVServer
- MediaPortal_v121_TVServerXBMC_plugin_bin_rev109
- opdenkapms XBMC PVR build: Eden-pvr Beta2 - build 65 - git rev. 62ff5bd
The TVServer is running OK. Then I installed the serverplugin. It seems to work also. I can get connection with telnet.
In XBMC - Settings - Addons - PVR... - there I cannot activate the plugin. When I click on activate, it stays deactivated. I attached a logfile.
One thing I dont understand. I can configure a database in the gentle.config from the server plugin. The wiki of Mediaportal says: "TV and Radio use SQL Server DB.". I copied the lines in the gentle.config. But where do I have to copy that config file. At the moment it is in the plugin folder of the mp-tvserver. I have the feeling that even if I delete the config file, nothing new happens.
Maybe someone can help me;-)
thanks mimas
btw: XBMC is wonderful, and I tested it just for some hours. So many things just work "out-of-the-box". I just need to get the live-tv running
logfile:
http://pastebin.com/6ZFSRjHJ
gentle.config:
http://pastebin.com/Kf0jtBR9
thanks for the reply.
I found the problem. The hint with deleting the TV*.db was the right direction. But it was the Addons*.db i had to delete. Now everything works fine.
thanks mimas
I am getting the same problem. Tried to to delete all the .db files in userdata but no joy. Any idea on what else to try?
hi,
i remove Addon*, TV* and EPG* but same since 2 days i use master build for tvheadend and opdenkamp's XBMC nighlty build.
Any idea ?
16:46:20 T:6224 NOTICE: DONE initializing playlistplayer
16:46:20 T:6224 NOTICE: EPG::CEpgContainer::Start - EPG thread started
16:46:20 T:6224 NOTICE: PVRManager - starting up
16:46:20 T:6324 ERROR: ADDON: Could not locate XBMC_Tvheadend_win32.pvr
16:46:20 T:6324 ERROR: PVR - PVR::CPVRClients::InitialiseClient - can't initialise add-on 'Tvheadend HTSP Client'
16:46:20 T:6224 NOTICE: initialize done
16:46:20 T:6224 NOTICE: Running the application...
16:46:20 T:6224 NOTICE: ES: Starting event server
16:46:20 T:5812 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
16:46:20 T:5812 NOTICE: UDP: Listening on port 9777
16:46:20 T:5228 NOTICE: -->Python Interpreter Initialized<--
16:46:21 T:4380 ERROR: CRemoteControl::Connect - failed to connect
16:46:27 T:6324 ERROR: ADDON: Could not locate XBMC_Tvheadend_win32.pvr
16:46:27 T:6324 ERROR: PVR - PVR::CPVRClients::InitialiseClient - can't initialise add-on 'Tvheadend HTSP Client'
According to your log, the actual TVHeadend addon file "XBMC_Tvheadend_win32.pvr" is missing...
The TVHeadend addon in the master branch was changed recently and after merging into my repo, I got some Windows build errors, so maybe the addon is indeed missing in the most recent nightly builds.
I'm currently building opdenkamp/master to double check that the build errors are not caused by my merge action. I will inform Opdenkamp if these build errors also affect his master branch.
Update: the tvheadend addon in opdenkamp/master (0c5dd3df0d) does not build under Windows. See also issue
#414.
Oh thx i tried to find error from my installation. but working with ppa
No prob i ll wait
fixed in the master branch now. new builds are underway.
Oh thx but another prob now
my log:
13:32:35 T:4896 NOTICE: -->Python Interpreter Initialized<--
13:32:36 T:3640 ERROR: CRemoteControl::Connect - failed to connect
13:32:38 T:4200 ERROR: AddOnLog: Tvheadend HTSP Client: CHTSPConnection::Connect - failed to read greeting from the backend
13:32:38 T:4200 ERROR: ADDON: Dll Tvheadend HTSP Client - Client returned bad status (1) from Create and is not usable
13:32:38 T:4200 ERROR: PVR - PVR::CPVRClients::InitialiseClient - can't initialise add-on 'Tvheadend HTSP Client'
13:32:39 T:4200 ERROR: AddOnLog: Tvheadend HTSP Client: CHTSPConnection::Connect - failed to read greeting from the backend
13:32:39 T:4200 ERROR: ADDON: Dll Tvheadend HTSP Client - Client returned bad status (1) from Create and is not usable
13:32:39 T:4200 ERROR: PVR - PVR::CPVRClients::InitialiseClient - can't initialise add-on 'Tvheadend HTSP Client'
13:32:41 T:4200 ERROR: AddOnLog: Tvheadend HTSP Client: CHTSPConnection::Connect - failed to read greeting from the backend
13:32:41 T:4200 ERROR: ADDON: Dll Tvheadend HTSP Client - Client returned bad status (1) from Create and is not usable
13:32:41 T:4200 ERROR: PVR - PVR::CPVRClients::InitialiseClient - can't initialise add-on 'Tvheadend HTSP Client'
13:32:42 T:4200 ERROR: AddOnLog: Tvheadend HTSP Client: CHTSPConnection::Connect - failed to read greeting from the backend
13:32:42 T:4200 ERROR: ADDON: Dll Tvheadend HTSP Client - Client returned bad status (1) from Create and is not usable
13:32:42 T:4200 ERROR: PVR - PVR::CPVRClients::InitialiseClient - can't initialise add-on 'Tvheadend HTSP Client'
13:32:43 T:4200 ERROR: AddOnLog: Tvheadend HTSP Client: CHTSPConnection::Connect - failed to read greeting from the backend
13:32:43 T:4200 ERROR: ADDON: Dll Tvheadend HTSP Client - Client returned bad status (1) from Create and is not usable
13:32:43 T:4200 ERROR: PVR - PVR::CPVRClients::InitialiseClient - can't initialise add-on 'Tvheadend HTSP Client'
13:32:44 T:4200 ERROR: AddOnLog: Tvheadend HTSP Client: CHTSPConnection::Connect - failed to read greeting from the backend
13:32:44 T:4200 ERROR: ADDON: Dll Tvheadend HTSP Client - Client returned bad status (1) from Create and is not usable
13:32:44 T:4200 ERROR: PVR - PVR::CPVRClients::InitialiseClient - can't initialise add-on 'Tvheadend HTSP Client'
13:32:45 T:4200 ERROR: AddOnLog: Tvheadend HTSP Client: CHTSPConnection::Connect - failed to read greeting from the backend
13:32:45 T:4200 ERROR: ADDON: Dll Tvheadend HTSP Client - Client returned bad status (1) from Create and is not usable
13:32:45 T:4200 ERROR: PVR - PVR::CPVRClients::InitialiseClient - can't initialise add-on 'Tvheadend HTSP Client'
13:32:46 T:4200 ERROR: AddOnLog: Tvheadend HTSP Client: CHTSPConnection::Connect - failed to read greeting from the backend
13:32:46 T:4200 ERROR: ADDON: Dll Tvheadend HTSP Client - Client returned bad status (1) from Create and is not usable
13:32:46 T:4200 ERROR: PVR - PVR::CPVRClients::InitialiseClient - can't initialise add-on 'Tvheadend HTSP Client'
13:32:47 T:5476 NOTICE: Storing total System Uptime
13:32:47 T:5476 NOTICE: Saving settings
13:32:47 T:5476 NOTICE: stop all
13:32:47 T:5476 NOTICE: PVRManager - stopping
13:32:47 T:4764 ERROR: PVRManager - PVR::CPVRManager::Process - failed to load PVR data
13:32:47 T:4200 ERROR: AddOnLog: Tvheadend HTSP Client: CHTSPConnection::Connect - failed to read greeting from the backend
13:32:47 T:4200 ERROR: ADDON: Dll Tvheadend HTSP Client - Client returned bad status (1) from Create and is not usable
13:32:47 T:4200 ERROR: PVR - PVR::CPVRClients::InitialiseClient - can't initialise add-on 'Tvheadend HTSP Client'
found the cause for this. it's a bug in lib/platform. working on a proper fix.
and the binaries have been updated too now.
Sorry but for me doesn't work with 2 differents windows:/
Certainly i did mistake.
I use your last master branch (commit ce4b766).
Execute both dependancy and start buildsetup.
I execute my bianries and when i execute addon tvheadend, it will not reconize addon.
19:50:13 T:2032 NOTICE: PVRManager - stopping
19:50:13 T:1716 ERROR: PVRManager - PVR::CPVRManager::Process - failed to load PVR data
19:50:13 T:2032 NOTICE: PVRManager - starting up
19:50:13 T:3688 ERROR: AddOnLog: Tvheadend HTSP Client: CHTSPConnection::Connect - failed to authenticate
19:50:13 T:3688 ERROR: ADDON: Dll Tvheadend HTSP Client - Client returned bad status (1) from Create and is not usable
19:50:13 T:3688 ERROR: PVR - PVR::CPVRClients::InitialiseClient - can't initialise add-on 'Tvheadend HTSP Client'
19:50:16 T:3688 ERROR: AddOnLog: Tvheadend HTSP Client: CHTSPConnection::Connect - failed to authenticate
19:50:16 T:3688 ERROR: ADDON: Dll Tvheadend HTSP Client - Client returned bad status (1) from Create and is not usable
19:50:16 T:3688 ERROR: PVR - PVR::CPVRClients::InitialiseClient - can't initialise add-on 'Tvheadend HTSP Client'
19:50:16 T:1540 ERROR: Texture manager unable to load file: special://masterprofile/Thumbnails/a/ae00650e.png
19:50:17 T:3688 ERROR: AddOnLog: Tvheadend HTSP Client: CHTSPConnection::Connect - failed to authenticate
19:50:17 T:3688 ERROR: ADDON: Dll Tvheadend HTSP Client - Client returned bad status (1) from Create and is not usable
19:50:17 T:3688 ERROR: PVR - PVR::CPVRClients::InitialiseClient - can't initialise add-on 'Tvheadend HTSP Client'
19:50:18 T:4076 ERROR: AddOnLog: Tvheadend HTSP Client: CHTSPConnection::Connect - failed to authenticate
19:50:18 T:4076 ERROR: ADDON: Dll Tvheadend HTSP Client - Client returned bad status (1) from Create and is not usable
19:50:18 T:4076 ERROR: PVR - PVR::CPVRClients::InitialiseClient - can't initialise add-on 'Tvheadend HTSP Client'
19:50:18 T:1540 ERROR: Texture manager unable to load file: special://masterprofile/Thumbnails/b/b32b1413.png
19:50:18 T:3944 ERROR: AddOnLog: Tvheadend HTSP Client: CHTSPConnection::Connect - failed to authenticate
19:50:18 T:3944 ERROR: ADDON: Dll Tvheadend HTSP Client - Client returned bad status (1) from Create and is not usable
19:50:18 T:3688 ERROR: AddOnLog: Tvheadend HTSP Client: CHTSPConnection::Connect - failed to authenticate
19:50:18 T:3688 ERROR: ADDON: Dll Tvheadend HTSP Client - Client returned bad status (1) from Create and is not usable
do the prebuilt binaries from my signature work? also, ensure that xbmc is using the updated add-on.
does it work with authentication disabled?
yallah Wrote:Sorry but for me doesn't work with 2 differents windows:/
Same goes for me, Using Windows Setup provided by Dushmaniac, Tvheadend addon is not recognized by XBMC.
