Well, I decided DVD Fab was my best solution so now I am trying to do Cowboys and Aliens. I am literally on hour 2 of it "opening blu ray source". Should I be going about it a different way like going into the disc structure and finding the actual file I need?
patseguin Wrote:Well, I decided DVD Fab was my best solution so now I am trying to do Cowboys and Aliens. I am literally on hour 2 of it "opening blu ray source". Should I be going about it a different way like going into the disc structure and finding the actual file I need?
I run across the same thing every once in a while. Seems like DVD Fab can't break the encryption. You may need another tool to break the encryption, then you can rip it.
htpc guy Wrote:I run across the same thing every once in a while. Seems like DVD Fab can't break the encryption. You may need another tool to break the encryption, then you can rip it.
What should I try? Something like Handbrake or MakeMKV?
