Good morning.
I'm in the stage to configure my remote control. I'm using this
Guide (German). Unfortunately there's no section for the PVR commands.
What do I wanna configure:
My previous sat-receiver had a key to select the last used channel. And I wonder if there's no such a command in XBMC-PVR. Is there a list about with the PVR related commands available?
musv Wrote:Good morning.
I'm in the stage to configure my remote control. I'm using this Guide (German). Unfortunately there's no section for the PVR commands.
I think 0 on my remote does this..
xxxnelly Wrote:I think 0 on my remote does this..
So it does.
Learn something new everyday. Very useful.
My remote has a button for the previous channel, I would like to configure for that behaviour. I have tried to configure it that way without any success. I added prevchannel in remote.xml like this:
<zero>Number0</zero>
<prevchannel>Number0</prevchannel>
With this in lircmap.xml:
<prevchannel>KEY_CHANNEL</prevchannel>
What am I doing wrong?
sronx Wrote:My remote has a button for the previous channel, I would like to configure for that behaviour. I have tried to configure it that way without any success. I added prevchannel in remote.xml like this:
I faced with the same issue. The stuff below works for me:
.xbmc/userdata/keymaps/lircmapext.xml (I guess "remote.xml" in your case):
<keymap>
<global>
<universalremote>
<obc103>XBMC.PlayerControl(Previous)</obc103>
</universalremote>
</global>
</keymap>
.xbmc/userdata/Lircmap.xml:
<obc103>BTN-PrevChan</obc103>
What I understand from xbmc manuals, extended button should be named "obc1..255". However 'XBMC.PlayerControl(Previous)' is the name of the action you need, which is part of built-in functions (see
http://wiki.xbmc.org/index.php?title=Lis..._functions)
First of all:
Just pressing 0 didn't change anything in my case. Didn't find a default setting too in der Default user configs.
(2012-02-24, 04:53)perskym Wrote: [ -> ]I faced with the same issue. The stuff below works for me:
I tried that solution, XBMC switches to a different channel, but it isn't the last called channel. Haven't found out a logic of which channel has been selected.
not to hijack this thread, but as well as a last channel function, when in the epg clicking select on a channel (regardless of it it's the current live channel) pops a menu with options for switch, add timer, and ok, with the program description.
is there a command to "switch" or record this item without the intermediate menu, and is there any skin development that would up the program info at the bottom of the epg grid ?
also it would be nice to have the next program details as well as the name on the tv page (seems a waste of space here, as there is very unlikely to be any image to display, so large empty box ?
many thanks, Will
So pressing 0 on a keyboard switches to the previous or last channel. But when using a remote how could you map a button to perform the same action? I don't see this documented anywhere. Thanks.
So when inputting a channel number which has a zero in it kodi will switch back to previous channel and close channel number dialogue. CLEVER. How do we disable this??
Edit: So I've noticed that as soon as the channel number dialogue pops up (pressing 1-9) the 0 will again input 0 and not swap channel. My bad!
I am having trouble with this as well. I would like to map another key on my remote, but can't find any documentation on where "0" triggers the previous channel.
I have it set to backspace with these lines on my custom keyboard.xml:
<FullscreenLiveTV>
<keyboard>
<backspace>Number0</backspace>
</keyboard>
</FullscreenLiveTV>
