2012-07-20, 16:06
either get a remote app for iphone/android/wp7(?) or you need an infrared remote/sensor. Or you get the remote from pulse eight. If you have the budget for it, that's what I'd recommend.
(2012-07-20, 13:48)dapex Wrote: [ -> ]my raspberry pi has arrived today.. I only plan on using this for XBMC.. whats the easiest way to control XBMC on the raspberry PI?
(2012-09-05, 02:05)JuanTwo Wrote: [ -> ]Sort of off topic... Just installed raspbmc on a class 4, 4gb Sandisk SDHC card. Runs great! Connected to my NAS and streams full HD perfectly. Problem is, when it scrapes, it stops at 300 movies. I have tried rebooting, manually telling it to update, but it doesn't want to list anything over the 300 movies, including my television programs. Any idea what is causing this? I can't find anything on the topic... Thanks in advanceAre you out of space? 4GB isn't very big and once the library scrapes all the images and caches them I wouldn't doubt your encroaching on space issues possibly?
(2012-09-07, 12:50)Danielowenuk Wrote: [ -> ]My Pi handles them ok, although biggest file I have is 10GB for movie.Good to know. (10GB for a 1080p movie is pretty sizable so that's probably a good sign so it's either long or not compressed much I guess?)
(2012-09-07, 12:50)Danielowenuk Wrote: [ -> ]DTS causes issues unless you have a DTS capable receiver.Of course. Luckily I do. :-)
(2012-09-07, 19:23)nickv2002 Wrote: [ -> ](2012-09-07, 12:50)Danielowenuk Wrote: [ -> ]My Pi handles them ok, although biggest file I have is 10GB for movie.Good to know. (10GB for a 1080p movie is pretty sizable so that's probably a good sign so it's either long or not compressed much I guess?)
(2012-10-18, 00:21)wickwire Wrote: [ -> ](2012-09-07, 19:23)nickv2002 Wrote: [ -> ](2012-09-07, 12:50)Danielowenuk Wrote: [ -> ]My Pi handles them ok, although biggest file I have is 10GB for movie.Good to know. (10GB for a 1080p movie is pretty sizable so that's probably a good sign so it's either long or not compressed much I guess?)
About the HD playback, I have the revision B model with 256MB RAM and the latest Raspbmc build installed - and whilst 1080p mkv playback works flawlessly, when I try to pull up the xmbc controls over the movie (overlay transparency effects) the movie playing in the background stutters. If I switch to SD media, no stuttering whilst playing with the options in the foreground. Also, the playback is running over SMB from a Network Share, on a Gigabit LAN.
Can anyone else confirm this issue? Is this a performance limitation on Pi (hardware) or is there still room for Raspmbc development/fine tuning?
Thanks and great work so far!
