Full Version: Music Videos not showing
Hello, I've just started using the Back Row skin, and it works fine with TV-Shows Movies and Videos just like I want it to.
But Music Videos even tho chosen MTV scraper will not show any files or music videos from the smb directory( remote location vids) - it only shows a black screen with the normal Back Row background?
Also, is there a hotkey for getting to favourite programs?
Hello - you'd need to scan your music videos into the library for anything to show. If the scraper isn't finding anything then it could be an issue with how they're named. It's not really a skin issue though you might find more help posting in general help.
Sorry I'm not sure if there is an XBMC hotkey for favourites - I know you can map it to a button by messing around with the keymapping though.
Cheers
