Full Version: [WINDOWS] USB Remotes stop working. Video/Xbmc still running
Ok so I cannot figure this one out.
For an unknown reason while using XBMC eden beta2 my harmony 900 and dinovo mini will both stop working inside xbmc. However xbmc is still running fine, and the video will continue to play. It happens randomly when in menus or while playing a video.
I can however put the htpc to sleep with my harmony, and through that I can reset xbmc but the remotes still wont respond.
Note they work fine outside of xbmc during this time.
Has anyone else experienced this issue?
I've seen symptoms like this when Windows things the shift or control keys are stuck down. This happens if Windows doesn't receive the "shift-up" signal from the remote. If you press the shift and control keys on the diNovo a few times does that fix the problem?
JR
Thanks for the reply! I'll give that a try next time it happens.
Could be the dinovo mini playing up. It's been a little fiddly lately.
