Hi when it try ro run Epix HD or ESPN on my apple tv 2 in xbmc I get error script failed no matter what I try. I've reloaded the plugin and other stuff but cannot get it to work.
thanks
I have Eden Beta 2 running as well. I also have Hulu, Icefilsm all of those work fine just not the 2 mentioned above. Should I post a log? I just need to find the post on how to do that.
thanks
Definitely post a log. Just tried EpixHD now and it works fine on my ATV2. How you logging in to Epix. Free Epix Account? Charter, etc,etc ...
Setp up a 2 weeks free trial using VPN (as I'm in Canada) Hulu and netflix work. I hvae it set for dishnet
gonefishing1975 Wrote:Setp up a 2 weeks free trial using VPN (as I'm in Canada) Hulu and netflix work. I hvae it set for dishnet
if youre just using the free trial, then set your login to epix.com account.
apw2607: these plugins have release threads.
please post in them...
Is epix HD a free account? or do we need to spend money after the free trial?
Reseman
