I'm trying to exclude some files with the fileextension *.strm
I'm using:
!IsEmpty($INFO[Window.Property(LatestMovie.1.Path)]*.strm)
But it doesn't work
Can someone help me out?
Use !substring($INFO[Window.Property(LatestMovie.1.Path)],.strm) if you wan't to exclude the movie if it has the extension strm.
`Black Wrote:Use !substring($INFO[Window.Property(LatestMovie.1.Path)],.strm) if you wan't to exclude the movie if it has the extension strm.
Thank you for your quick replay!
I've tried it, but with no luck...
I've tested it by removing the "!" before the substring but the movie doesn't show, the movie is een streaming file.
<item id="1">
<icon>$INFO[Window.Property(LatestMovie.1.Thumb)]</icon>
<label>$INFO[Window.Property(LatestMovie.1.title)]</label>
<onclick>$INFO[Window.Property(LatestMovie.1.Path),PlayMedia(,)]</onclick>
<visible>!Skin.HasSetting(HomeRandom) + !IsEmpty(Window.Property(LatestMovie.1.Title)) + !substring($INFO[Window.Property(LatestMovie.1.Path)],.strm)</visible>
</item>
`Black Wrote:Try
!substring(Window.Property(LatestMovie.1.Path),.strm)
Thank you very much `Black!
Now it's working perfectly!
