Full Version: No option for add source to Pictures in Eden Beta 2
I no longer have the option to add source in the Pictures category. This option exists and works just fine in the Video and Music categories. I have already made sure that the "Add Source" button is enabled under the System/Settings/Appearance/File Lists. The only tab present under Pictures is Addons. When I select it the only option is to "Get More" which only lets me select iPhoto, Flickr,Google and The Big Picture but no Add Source.
I am running iOS 4.3.3 on ATV2 with Eden Beta 2.
You don't need to use the add source under pictures. You can use any add source as long as you specify the type of content is pictures.
What you need to do is point to Main Pictures Menu, then only the add-ons will appear but do NOT go down to them. Keep the upper main Pictures tab highlighted and press the middle remote button. New menu will open and it will show the Add Source option.
