Full Version: error XBMC Eden 11.0 Beta 2
Hi, I´m new on the forum.
I have an apple tv 1 jailbreaked, with XBMC dharma 10, and works great by 7 months, when I try to update my xbmc to the new eden beta 2 version shows me an error every time I try to open any addon or any program, the error is this:
scrapertools.py", line 438, in downloadpage
data=handle.read()
UnboundLocalError: local variable 'handle' referenced before assignment
I paste the complete log too:
http://pastebin.com/1eETzVjK
If anyone could help me I,ll apreciate a lot.
Thank you and sorry for my english.
The error is coming from Pelisalacarta, which has not been updated for Eden.
Thank you but the problem is not only with pelis a la carat is with all the addons.
Please let me know what I can do.
18:49:00 T:2684407808 DEBUG: Unloading: libcrystalhd.dylib
18:49:00 T:61060096 ERROR: ADDON: extension 'downloader/' is not currently supported for service addon
18:49:02 T:61101568 ERROR: Previous line repeats 2 times.
18:49:02 T:61101568 DEBUG: Using proxy http://:8080
18:49:03 T:61060096 ERROR: ADDON: extension 'downloader/' is not currently supported for service addon
18:49:06 T:61060096 DEBUG: ADDON: cpluff: 'Not all directories were successfully scanned.'
18:48:51 T:61060096 INFO: easy_aquire - Created session to http://bluecop-xbmc-repo.googlecode.com
18:48:51 T:61060096 WARNING: FillBuffer: curl failed with code 22
18:48:51 T:61060096 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
18:48:51 T:61060096 ERROR: Open - failed to open source <http://bluecop-xbmc-repo.googlecode.com/svn/trunk/addons.xml.md5>
18:48:51 T:61060096 DEBUG: CFileCache::Open - opening <svn/trunk/addons.xml> using cache
18:48:51 T:61060096 DEBUG: Using proxy http://:8080
18:48:51 T:61060096 DEBUG: FileCurl::Open(0x103d4ff0) http://bluecop-xbmc-repo.googlecode.com/...addons.xml
18:48:52 T:61060096 WARNING: FillBuffer: curl failed with code 22
18:48:52 T:61060096 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
18:48:52 T:61060096 ERROR: Open - failed to open source <http://bluecop-xbmc-repo.googlecode.com/svn/trunk/addons.xml>
18:48:52 T:61060096 ERROR: Repository bluecop Add-on Repository returned no add-ons, listing may have failed
18:48:52 T:61060096 DEBUG: CFileCache::Open - opening <svn/trunk/addons/addons.xml.md5> using cache
18:48:52 T:61060096 DEBUG: Using proxy http://:8080
18:48:52 T:61060096 DEBUG: FileCurl::Open(0x103b5510) http://sparetime.googlecode.com/svn/trun...ns.xml.md5
18:48:52 T:61060096 INFO: easy_aquire - Created session to http://sparetime.googlecode.com
18:48:52 T:62424064 DEBUG: Thread XFILE::CFileCache start, auto delete: 0
18:48:52 T:62424064 INFO: CFileCache:Tonguerocess - Hit eof.
18:48:52 T:62424064 DEBUG: Thread XFILE::CFileCache 62424064 terminating
18:48:52 T:61060096 DEBUG: CFileCache::Open - opening <Eldorados/eldorado-xbmc-addons/raw/master/addons.xml.md5> using cache
18:48:52 T:61060096 DEBUG: FileCurl::Open(0x10382fb0) https://github.com/Eldorados/eldorado-xb...ns.xml.md5
18:48:52 T:61060096 INFO: easy_aquire - Created session to https://github.com
18:48:52 T:61060096 WARNING: FillBuffer: curl failed with code 56
18:48:52 T:61060096 ERROR: Open - failed to open source <https://github.com/Eldorados/eldorado-xbmc-addons/raw/master/addons.xml.md5>
18:48:52 T:61060096 DEBUG: CFileCache::Open - opening <Eldorados/eldorado-xbmc-addons/raw/master/addons.xml> using cache
18:48:52 T:61060096 DEBUG: FileCurl::Open(0x103de090) https://github.com/Eldorados/eldorado-xb...addons.xml
18:48:52 T:61060096 ERROR: Open - failed to open source <https://github.com/Eldorados/eldorado-xbmc-addons/raw/master/addons.xml>
18:48:52 T:61060096 ERROR: Repository Eldorado's XBMC Addons returned no add-ons, listing may have failed
18:48:53 T:61060096 ERROR: ADDON: extension 'downloader/' is not currently supported for service addon
18:48:53 T:61060096 DEBUG: CFileCache::Open - opening <addons/eden-pre/metadata.themoviedb.org/metadata.themoviedb.org-3.0.8.zip.md5> using cache
18:48:53 T:61060096 DEBUG: Using proxy http://:8080
18:48:53 T:61060096 DEBUG: FileCurl::Open(0x12fa2a50) http://mirrors.xbmc.org/addons/eden-pre/....8.zip.md5
18:48:53 T:61829120 DEBUG: Thread XFILE::CFileCache start, auto delete: 0
18:48:53 T:61829120 INFO: CFileCache:Tonguerocess - Hit eof.
18:48:53 T:61829120 DEBUG: Thread XFILE::CFileCache 61829120 terminating
18:48:53 T:61166080 DEBUG: Using proxy http://:8080
18:48:54 T:61060096 DEBUG: CFileCache::Open - opening <addons/eden-pre/weather.wunderground/weather.wunderground-0.0.4.zip.md5> using cache
18:48:54 T:61060096 DEBUG: Using proxy http://:8080
18:48:54 T:61060096 DEBUG: FileCurl::Open(0x12fb1240) http://mirrors.xbmc.org/addons/eden-pre/....4.zip.md5
18:48:54 T:61060096 INFO: easy_aquire - Created session to http://mirrors.xbmc.org
Quote:DEBUG: Using proxy http://:8080
That might be the problem. Did you have a proxy server enabled, but without being filled out? (Settings -> Network -> Internet access)
Hi @ned scott I follow that route and the proxy is eneabled, in server is a blank, port 8080, and user name and password blank.
Im sure like you soy that is something that is avoid to connect to Internet but I didn't found what is the problem, let me know please if there another log of some information that that help you to help me.
Thanks again.
Deactivate the proxy then!
Hi @Memphiz, I tried deactivate proxi, but didn´t work, I sending you the log that apperars me.
http://pastebin.com/zzz01TcZ
I´ll apreciate a lot your help.
thank you.
Now it works thank you, I unistall allthe addons that i have and begin to install one by one.
thank you
My webserver failes to start too. I have Beta 3. Part of log below.
** log removed **
pro510 Wrote:My webserver failes to start too. I have Beta 3. Part of log below.
** log removed **
Post the full log to pastebin and put the link in here. Don't forget enable Debugging - else the logfile is useless ...
