Full Version: XBOX DVD dongle and Maverick 10.10 not working
After i installed the latest updates my DVD dongle is no longer working.
I think im having trouble with the kernel driver vs the module lircd.
[email protected]:~$ cat /var/log/syslog | grep lir
Feb  3 07:41:49 xbmc lircd-0.8.7-pre3[8994]: caught signal
Feb  3 07:42:07 xbmc lircd-0.8.7-pre3[10631]: lircd(default) ready, using /var/run/lirc/lircd
Feb  3 07:42:19 xbmc lircd-0.8.7-pre3[10631]: accepted new client on /var/run/lirc/lircd
Feb  3 07:44:03 xbmc lircd-0.8.7-pre3[10631]: removed client
Feb  3 07:44:12 xbmc lircd-0.8.7-pre3[10631]: accepted new client on /var/run/lirc/lircd
Feb  3 07:45:17 xbmc kernel: [   11.452588] lirc_dev: IR Remote Control driver registered, major 61
Feb  3 07:45:17 xbmc kernel: [   11.520935] lirc_atiusb: USB remote driver for LIRC $Revision: 1.88 $
Feb  3 07:45:17 xbmc kernel: [   11.520945] lirc_atiusb: Paul Miller <[email protected]>
Feb  3 07:45:17 xbmc kernel: [   11.521056] lirc_dev: lirc_register_driver: sample_rate: 0
Feb  3 07:45:17 xbmc kernel: [   11.521245] lirc_atiusb[2]:  on usb4:2
Feb  3 07:45:17 xbmc kernel: [   11.521361] usbcore: registered new interface driver lirc_atiusb
Feb  3 07:45:28 xbmc lircd-0.8.7-pre3[740]: accepted new client on /var/run/lirc/lircd
Feb  3 07:45:35 xbmc lircd-0.8.7-pre3[740]: caught signal
Feb  3 07:45:35 xbmc lircd-0.8.7-pre3[1614]: lircd(default) ready, using /var/run/lirc/lircd
Feb  3 07:45:35 xbmc lircd-0.8.7-pre3[1614]: caught signal
Feb  3 07:45:35 xbmc lircd-0.8.7-pre3[1646]: lircd(default) ready, using /var/run/lirc/lircd
Feb  3 07:45:35 xbmc lircd-0.8.7-pre3[1646]: accepted new client on /var/run/lirc/lircd
Feb  3 07:45:35 xbmc lircd-0.8.7-pre3[1646]: could not get hardware features
Feb  3 07:45:35 xbmc lircd-0.8.7-pre3[1646]: this device driver does not support the LIRC ioctl interface
Feb  3 07:45:35 xbmc lircd-0.8.7-pre3[1646]: did you mean to use the devinput driver instead of the default driver?
Feb  3 07:45:35 xbmc lircd-0.8.7-pre3[1646]: Failed to initialize hardware
Ive tried this
http://forum.xbmc.org/showthread.php?tid=98348
But it still fails.
2.6.35-27-generic-pae
[email protected]:~$ cat /var/log/dmesg | grep lir
lirc_atiusb            13219  0
lirc_dev                9510  1 lirc_atiusb
Bus 004 Device 002: ID 045e:0284 Microsoft Corp. Xbox DVD Playback Kit
lsdev returns
lirc0
lircd
I wish i never installed the updates as everything was working great. any help untangling this mess would be appreciated.
ThanksNerd
Got it working,
I had to change hardware.conf
/dev/input/event2 to /dev/lirc0
wolla it started working after restarting lirc
