I own 2 ATV2. I install the latest eden 11.0 b2 on both and have at both atv2 the same configuration.
The problem is, if I navigate to TV or movies it needs at the slow machine a very long time to show me the seasons or films. At the quick machine I get the output after 2 seconds.
I use MySQL and a network share for Thumbs.
Here is the xbmc.log
http://pastebin.com/erWXfpHc
Here is the advancedsettings.xml
http://pastebin.com/X3wMZdJW
I found a similar error at the web and the mean a re jailbreak can help. I do this but it don't help.
You should add the log for the other atv2 then ... and tell us which is which ...
Well its obvious:
fast:
238.15:39:58 T:110063616 INFO: Loading user windows, path /private/var/stash/Applications/XBMC.frappliance/XBMCData/XBMCHome/addons/skin.confluence/720p
239.15:39:58 T:110063616 DEBUG: Load Skin XML: 612.90ms
slow:
238.15:40:53 T:110813184 INFO: Loading user windows, path /private/var/stash/Applications/XBMC.frappliance/XBMCData/XBMCHome/addons/skin.confluence/720p
239.15:40:53 T:110813184 DEBUG: Load Skin XML: 14234.36ms
Don't ask me why ...
You could verify that its allways that "Load Skin XML" which slows it down on your slow box...
I found the error and its very strange.
I use both machine with mysql, same username and password.
If I start the slow machine, the MySQL admin interface shows me an unautorisaation access with an unknown user. This comes from the slow ATV2.
I saw also that connection that works fine shows me always a hostname. The connection that don't work shows me only the IP from the slow atv2.
The next step was very easy. I configure the DNS to resolve the ip to a name.
Bingo, now it works.
I don't understand 2 things.
1. Why the atv2 cannot connect to the mysql
2. Why the atv2 shows me the seasons and movies without a connection.
But both questions are not based on xbmc issue.
I have a last question. Sometimes the ATV don't boot. I saw the apple, it goes away and then nothing. I recicle the power and than it works. Any hint? I know its not xbmc, but I think you have experience and you have a hint...:-)
So have a nice weekend and thanks for your attention.
the none booting issue is a jailbreak problem - we have to hope that there will be a new seasonpass which fixes it. About the mysql thing - there is an entry in our wiki which describes a setting for switching reverse lookups off on thy mysql server...
Many Thanks for your exelent support.
