Full Version: [REQUEST] modded Textures.xbt.......
hi BN i have to ask a thing.
in my house i have a couple of istallations with of the XBMC and aeonnox. one of this is installed on a asus eeepc 701 4g (the firs of the eeepc family) connected to a 32inch tv.
i have windows xp professional (lite) and the eden beta2 installed. the aeon nox version is the one on the offical repo.
my problem is that all the backgrounds of aeonnox are too slow to be loaded (my processor is too old).
if it is not t a problem for you, could you post a Texture.xbt without backgrounds.
in the meantime i'm thinking to another solution.
thank in advance,
peppe
sorry for the wrong post, i see that the backgrounds are in their own folder. so i have renamed the folder and i have solved my problem.
so xbmc is pretty good also on my old eeepc.
if you want you can delete this topic
peppe
You should be able to also grab the uncompressed textures from the svn.
