Full Version: update XBMCbuntu
hi there.
i’ve installed a version of xbmcbuntu (got it at xbmcfreak) from a few days ago.
is it possible to update my version without starting all over again?
thanks for your help
Should just be able to do:
sudo apt-get update
sudo apt-get install xbmc
This will install a new build of XBMC if one is available on the PPA. I'm pretty sure the XBMCFreak/XBMCbuntu repo is the one by Mario Sitz who keeps it pretty up to date with current builds.
done some digging in my XBMCfreak/XBMCbuntu install and looked at the sources lists. It uses the official unstable ppa.
Then add the mario-sitz repo if you want bleeding edge.
