Greetings XBMC community!
I am trying to convert an old Dharma compatible skin over to Eden, everything works great beside the –fanarts. It does not show any fararts in “showcase” view at all. The skin is a heavily customized personal MOD based on the original AEON version and I really want to avoid to install a new Eden compatible skin just because of this, but I guess in the end I have no choice if I cannot fix this issue =(
I have tried for serveral hours to trouble shoot and modify the “MyVideoNav.xml” and “Viewtype_Showcase.xml” to get the fanarts to show but without success. I’m not sure what has changed in Eden that causes this with older skins regarding the fanarts.
I would really appreciate any help regarding this issue.
Many thanks in advance. Cheers
What InfoLabel are you using?
Maybe you can upload the xml from the view so that we can check...
mm
Greetings Mr. Mad-Max and thanks for the reply.
I’m using “$INFO[Fanart.Image]” as texture and that used to load just fine in Dharma/Camelot/Babylon and older but it is just showing a black image in Eden. I have tried to use the default Eden “.Confluence” skin as a base guideline to fix this issue but so far without any success.
/Edit: It does not seem to be possible to attatch .xml files in this forum. I’ll upload it to a external site as .zip files and post it later tonight when I get home.
Thanks in advance. Moments like this makes me wonder how we could ever live without fanarts just a couple of years ago =). Cheers
Just a quick hint, try
$INFO[ListItem.Property(Fanart_Image)]
Might help...if not, I'll wait for the uploaded xml...
cheers
Thanks for the reply, unfortunately that did not work and the *-fanart are still not loading.
I’ll attach the
MyVideoNav.xml file below.
/EDIT: I couldn’t attach the Viewtype_Showcase.xml file due to character limit in this forum so I uploaded them as a .zip file below if needed.
(.zip file of the 720p folder:
http://www.yourfilelink.com/get.php?fid=757695
Cheers and thanks in advance.
MyVideoNav.xml:
<window id="25">
<defaultcontrol always="true">50</defaultcontrol>
<allowoverlay>yes</allowoverlay>
<controls>
<control type="multiimage">
<include>Background_SingleImage</include>
<imagepath>backdrops/default_movies</imagepath>
<info>Skin.String(CustomMovies)</info>
<visible>!Skin.String(CustomMoviesFolder)</visible>
<visible>Skin.HasSetting(videomovies)</visible>
<visible>Skin.HasSetting(nomoviefanart)|IsEmpty(listitem.property(fanart_image))</visible>
<visible>[IsEmpty(Fanart.Image)+IsEmpty(listitem.property(fanart_image))] | Skin.HasSetting(notvfanart)</visible>
</control>
<include>Background_ImageFolder</include>
<info>Skin.String(CustomMoviesFolder)</info>
<visible>Skin.String(CustomMoviesFolder)</visible>
<animation effect="fade" start="0" end="100" time="300" condition="Skin.HasSetting(nomoviefanart)|IsEmpty(listitem.property(fanart_image))">Conditional</animation>
</control>
<imagepath>backdrops/default_tvshows</imagepath>
<info>Skin.String(CustomTV)</info>
<visible>!Skin.String(CustomTVFolder)</visible>
<visible>Skin.HasSetting(videotv)</visible>
</control>
<info>Skin.String(CustomTVFolder)</info>
<visible>Skin.String(CustomTVFolder)</visible>
</control>
<control type="largeimage" id="102">
<include>FullscreenDimensions</include>
<visible>Control.IsVisible(57) + [[Container.Content(movies) + !Skin.HasSetting(nomoviefanart)] | [Container.Content(tvshows) + !Skin.HasSetting(notvfanart)]] + !IsEmpty(listitem.property(fanart_image))</visible>
<fadetime>400</fadetime>
<texture>$INFO[listitem.property(fanart_image)]</texture>
<include>Animation_FanartFade</include>
</control>
<control type="image">
<visible>[Container.Content(seasons) | Container.Content(episodes)] + !IsEmpty(Fanart.Image) + !Skin.HasSetting(notvfanart)</visible>
<animation effect="fade" end="0" time="200">WindowClose</animation>
<animation effect="fade" start="0" end="100" time="600">VisibleChange</animation>
<texture>$INFO[ListItem.Property(Fanart_Image)]</texture>
<!--texture>$INFO[Fanart.Image]</texture>-->
</control>
<include>Furniture_WallBackground</include>
<control type="group">
<include>Animation_OpenCloseZoom</include>
<include>Furniture_Time</include>
<include>Conditions_HiddenByInfoPages</include>
<include>Furniture_WindowRSS</include>
<include>Furniture_MediaPanel</include>
<include>Objects_ShowcaseMenuPanel</include>
<include>Viewtype_Wall</include>
<include>Furniture_WallTime</include>
<include>Furniture_WallRSS</include>
<include>Animation_MediaMenuPosition</include>
<include>Objects_MediaLogo</include>
<texture>windows/logo_movies.png</texture>
</control>
<control type="label">
<label>31033</label>
<include>Objects_MediaLabel</include>
</control>
<label>31032</label>
</control>
<control type="grouplist" id="7000">
<include>Animation_MediaMenuSlide</include>
<include>Objects_MediaMenuGroup</include>
<control type="button" id="900">
<label>$LOCALIZE[31050] $INFO[Container.ViewMode]</label>
<include>Objects_MediaMenuButton</include>
<onclick>SetFocus(69)</onclick>
<visible>!Container.Content(episodes)</visible>
</control>
<control type="button" id="930">
<visible>Container.Content(episodes)</visible>
<onclick>Notification(,$LOCALIZE[31756],15,)</onclick>
</control>
<include>Objects_FlattenFlowButton</include>
<control type="button" id="3">
<label>103</label>
</control>
<control type="togglebutton" id="901">
<label>31065</label>
<altlabel>31064</altlabel>
<usealttexture>Skin.HasSetting(nomoviefanart)</usealttexture>
<onclick>Skin.SetBool(nomoviefanart)</onclick>
<altclick>Skin.Reset(nomoviefanart)</altclick>
<visible>Window.IsActive(25) + Skin.HasSetting(videomovies) + Control.IsVisible(57)</visible>
</control>
<control type="togglebutton" id="902">
<usealttexture>Skin.HasSetting(notvfanart)</usealttexture>
<onclick>Skin.SetBool(notvfanart)</onclick>
<altclick>Skin.Reset(notvfanart)</altclick>
<visible>Window.IsActive(25) + Skin.HasSetting(videotv) + Control.IsVisible(57)</visible>
</control>
<include>Objects_FlagsButton</include>
<include>Objects_ThumbsButton</include>
<include>Objects_WallGridButton</include>
<include>Objects_WallBackdropButton</include>
<control type="togglebutton" id="14">
<description>Watched Toggle Button</description>
<label>31059</label>
<altlabel>31058</altlabel>
<visible>[Skin.HasSetting(videomovies) + !Skin.HasSetting(nomenumoviewatched)] | [Skin.HasSetting(videotv) + !Skin.HasSetting(nomenutvwatched)]</visible>
</control>
<control type="button" id="8">
<label>137</label>
<visible>[Skin.HasSetting(videomovies) + !Skin.HasSetting(nomenumoviesearch)] | [Skin.HasSetting(videotv) + !Skin.HasSetting(nomenutvsearch)]</visible>
</control>
<control type="button" id="11">
<label>31057</label>
<onclick>XBMC.ReplaceWindow(MyVideoFiles)</onclick>
<visible>!Skin.HasSetting(nomenufiles)</visible>
</control>
<include>Objects_VideoSetupButton</include>
<include>Objects_MediaDebugButtons</include>
</control>
</control>
<include>Viewtype_List</include>
<include>Viewtype_Showcase</include>
<include>Viewtype_Coverflow</include>
</control>
<include>ViewChange</include>
<include>Background_ContextBlack</include>
<include>Furniture_Debug</include>
</controls>
</window>
Update: I’m currently on progress of updating the entire skin based on the EDEN baseline .confluence skin code in order to make it 100% compatible and future proof. I just realized that there are more problems than just the fanart issue (lots of minor ui bugs here and there) due to the age of the skin and it’s now outdated code and I guess it is time to make that move instead of trying to fix every broken bit one by one.
I was just a bit lazy and wanted to avoid this if possible but I guess it is better to do it now than years from now when I’m even (more) older than now with less energy =)
Thanks again mad-max for the offer to help. Cheers
