Full Version: Can I use this?
I have a Hp a1250n
Here is the spec page
http://h10025.www1.hp.com/ewfrf/wc/docum...r1002_usen
Then add this Zotac G210.
http://www.newegg.com/Product/Product.as...tac%20G210
Im gonna build a new system for home, was hoping to recycle the old one into my first htpc.
It has to play bluray rips.
Thanks Scott
Should be pretty close... but you'll need GFX acceleration to work so it's going to be Win7 or a flavour of gfx card that works with Linux.
Consider: http://forum.xbmc.org/showthread.php?tid=61340
